I was checking this video out and thought maybe this was ok until he said that his methods were for street Jeeps and not for off roading. Any other thoughts? He mentioned that he put springs from a JK on his TJ. Any thoughts on that?
I thought this was going to be a thread about me.
I'm just poking fun of me being full of junk.I honestly didn't see it that way. I'm still not seeing it.
I didn't even notice that! Went back and saw that it was the red one.As soon as I saw the angry grill I turned it off.
All he does is come here to promote his YouTube channel.
Chinese knock-offs. Some folks here on the forum would buy the same parts as this guy.Oh Jesus
Those headlights and markers are the biggest Jeep crime in this video.
You ran 35” tires at 2k on the highway? Wow....never seen a Jeep that could hold speed at that rpm without the pedal being on the floor (lugging).On the money, he is absolutely correct regarding gas mileage and driveline stress. Tall gears are harder on the clutch and engine Low gearing increases stress after the clutch, ujoints and axles. Lugging is about load, not just rpm. To accelerate you need to be closer to 3K rpm, but just cruising around, 2K rpm is not lugging unless you try to accelerate... hard. And 2K rpm does deliver better gas mileage under no load than 3K rpm. The problem is too many people don't drop a gear when they should......
Which explains why no one is building new vehicles with a clutch anymore.
And he qualifies his choices, he mostly drives on the street. He flat out says if you are more off road, you might benefit from deeper gears.
