I was afraid of that. Thanks.If it's anything like the lower steering shaft, the only way to get a new joint is buy a whole new shaft.
Thanks Andy. Definitely got a problem. The joint I circled on the part 11 above does not rotate in a circle, when turn the wheel it rotates in a oblong rotation. I can feel it in the wheel.If you're 100% sure that you've got an issue... Get the whole deal...as well as the bearing and go ahead and grease the snot out of the bearing that the shaft runs in.
I've been down this road and it amazed me how much the least amount of slop in the system could affect the steering both at very low speed off-road and normal driving on the road.
Personally I would not go the route of the borgerson higher end replacement shaft... I know they make great products and their shaft could handle a dump truck... But mine had tolerance issues that made it unusable.... It simply was too small where it went through the bearing and that's the wrong place to have a tolerance issue.
Good luck Hop,
Andy
I'm trying to remember how it's purchased... If you go to a yard then it's whatever you can find but if you ordered I think you have to order the whole shaft with the bearing... I may be wrong but I think once you get over to the dealership or wherever you get it that's the way they're going to want to order it...There's no law that says you have to buy the whole thing if they sell them separate... If you can just do the upper shaft and you don't have any excess movement at the big bearing or anything you'll probably be fine.Thanks Andy. Definitely got a problem. The joint I circled on the part 11 does not rotate in a circle, when turn the wheel it rotates in a oblong rotation. I can feel it in the wheel.
When you said replace the whole thing you mean just the whole " part 11 upper shaft intermediate"??View attachment 216559
