Greetings all.
I am in the process of replacing bushings and more on my '97 Sport.
It has an older (pre-2003) Pro Comp Stage 2 4" lift.
I am referring to the lowest bolt on the rear lower control arm where it attaches to the axle.
Based on the Pro Comp instructions, it is an OE bolt and nut.
I have removed the nut, but have been unable to get the bolt out of the bracket.
It is obstructed by the brake backing plate.
I have tried several angles and some mild prying with no success, then the night took over.
Is this a common situation?
Is there any reasonable solution other than removing the backing plate?
The issue has presented itself on the passenger side, but appears it will be an issue on the driver's side as well.
(I haven't managed to break the driver's side bolt loose yet to check ... more fun to be had there)
If you have any questions, please ask.
Thank you very much for any help you may provide.
Take care.
Take care.
