Issues after LED tail light install
DillonR
Indiana
I have a 2000 TJ and I just put new LED brake lights on it. I got them from amazon. Wired them all up. I got running lights working. Reverse lights working. The ground is fine I checked it multiple times. But my brake lights aren’t working and my turn signal is hyper flashing. So I install the LED flasher. Still don’t fix it. So I do some research and put on a new turn signal switch. Still not avail. Any help?
https://www.amazon.com/dp/B07W52GCST/?tag=wranglerorg-20
Which LED flasher relay did you install? Please use links, not screenshots. 👍
I don't think that the flasher would stop the brake lights from working. While somebody presses the brake pedal, check for voltage at the connection. There might be something else going on.
When I installed LED tail lights, I too had hyperflashing, but the brake lights worked. An LED flasher fixed that. It happened to be the one that JESTER801 recommended.
https://www.amazon.com/dp/B000JZ79NC/?tag=wranglerorg-20
You need the Tridon EP26 as linked, but I'm not sure that will do anything to fix up the brake lights. Might have something else going on. Not sure what is going on but I would change the flasher first and reevaluate the situation after that. If still no brake lights, check all the fuses.
I have seen some weird situations where the flasher shorted a fuse because it was the wrong flasher, but I can't say that is the case for you.
