1. It's time to vote for the July 2018 "Ride of the Month"! Click here to vote. Voting will end on June 30th.
    Dismiss Notice
It's time to shop for tires
Discussion in 'TJ Wheels & Tires' started by alittleoff, May 11, 2018.
  1. billiebob
    billiebob TJ Addict
    Oct 31, 2015
    1,822
    1,555
    Kootenays, BC, Canada
    There was a tire calculator which listed ALL the comparable tires. I cannot find it but it was a greatresource.
  2. alittleoff
    alittleoff Member
    Thread Starter
    Apr 27, 2018
    89
    44
    So. Cal.
    Watched a few and seemed ok, but I'll wait for the hype and price to go down.
  3. alittleoff
    alittleoff Member
    Thread Starter
    Apr 27, 2018
    89
    44
    So. Cal.
    I've got a 4-Runner with BFG AT KM2 for the street and fire roads. But the Jeep gets treated different. AT's won't cut it. My 35" GY MT/R's have aged out. And I'm going bigger because I can. I won't claim to know the terrain in Canada, but here in So. Cal. I do rocks. And gumbo is something I make for dinner.
    billiebob likes this.
  4. alittleoff
    alittleoff Member
    Thread Starter
    Apr 27, 2018
    89
    44
    So. Cal.
    I picked up my new tires this morning from our local tire shop. And then spent a few hours installing the drain valves in my new Allied BL's. I'll mount the tires this weekend, then drive around for a few miles and then get them balanced.
  5. alittleoff
    alittleoff Member
    Thread Starter
    Apr 27, 2018
    89
    44
    So. Cal.
    After I mounted the tires I drove it around for a few days before I got them balanced. It was better than I expected. At 55 mph, I noticed a little shake in the front. At the tire shop, 4 of the 5 only needed 3-4 oz. per tire. The 5th, read 14 0z. No Bueno. I took the tires back home and worked on the 5th one. I drained the air, removed the bolts and ring, and then turned it over and spanked it with my Hi-Lift jack to break the bead. I then rotated it 180*, torqued the ring down and aired up to seat the inner bead. Drove back to the tire shop and it balanced out at 4 oz.
    In the past couple of days, I've been playing with the air pressure. I started at 25 cold, which went up to 28 hot.
    I ended up at 20 cold, 23 hot for a for a good chalk line on pavement. And 10 psi hot when aired down.
    Also a pic of the drain valve too.
    #25 alittleoff, Jun 12, 2018
  6. alittleoff
    alittleoff Member
    Thread Starter
    Apr 27, 2018
    89
    44
    So. Cal.
Share This Page
