Here we go again!
I actually get more responses and input from the Off-Topic forum than I do actual home improvement forums, so I thought I'd write up my adventures (or incidents) in finishing my basement of our home.
I'm pretty excited to get rolling on this project. I learned a lot from finishing the basement in my first house. The footprint was substantially smaller: a little over 1,000 square feet with probably around 900 square feet of actual finished basement and 100 square feet of utility and storage space.
This time around, I have about 1,000 square feet of finished space to work with (and yes, I know the wood I've got in the photo isn't nearly enough to finish that amount of space; I was at the mercy of my toddler's mood at the hardware store).
Some notes on what I'm looking to accomplish or just to reference:
Here's a very, very rough draft of my home theater layout and a bullet point list of ideas that I'm considering, though are likely to be revised in one way or another as I go:
- The home theater will be its own entity, not an open floor plan to the rest of the basement.
- AV closet: a space for all the gear. I considered using media tables or cabinets under the screen. Being that this is a basement set-up, though, I want to keep equipment away from the floor. I've had good luck with IR repeaters.
- Check on Harmony Elite remotes and hubs.
- Omit closet door in favor of exposed devices and better ventilation.
- Double-walling closet in absence of door?
- Two rows of seating using risers. The floor-to-joist measurement is about 8' 6", so risers for the back row of seating would be nice. I also like the idea of risers mimicking theater seating. Seating type TBD, probably couches.
- "Room within a room" configuration as well as resilient channels in the ceiling.
- I've seen some folks wish that they'd added a wooden sub-floor rather than building directly from the concrete in order to get more out of the bass effects.
- Check Dricore subfloor option.
- I have absolutely no idea what kind of projector to get or what screen size to consider.
- The wall that will hold the screen currently has a measurement of 161 3/4" W x 191" D x 101" H.
- I've worked at a number of concert venues that use wide PVC pipes (one tech referred to them as "rabbit holes") to run cables. They're wide enough that multiple cables can be run through them and changed out if need-be without much effort. I'm considering doing the same thing.
