When at static ride (only compressing the suspension with the vehicles weight on level ground) the shock is sitting at 50% of its full travel rate so you have the same amount of up travel that you would down.
I know. That wasn't the question.
Here I was thinking I actually knew useful infoI know. That wasn't the question.
They look great thanks for the pictureLove my JCR Highlines, I got the Crusader mid-width fenders. They look great and the extra clearance can't hurt. I like that highlines are the kind of thing that you may not notice unless you're a Jeep person, and you likely even need to be a TJ person in order to see whats really going on.
Hey Chris do you have a close up pic of your highline fenders ?Is the shock fully bottomed out at this point? What is the travel-bias of the shocks?
Without a doubt on the rears - I'm still new to TJ's and was amazed how true-to-size 35"s when centered in the wheelwells don't even come close to touching. Some of my full-sized rigs have trouble with that!The rears have more room than the front. And you have to speak in terms of the shock travel bias. That describes more of what is really going on than just the length or bump stop or lift height.
A rig with 2" up, 9" down is built differently than one with 5.5" up, 5.5" down.
For highlines to really be functional as a suspension modification, the suspension needs to be built to make use of the highlines.
Also agreed on keeping bias in mind. Maybe it's because I spend most of my days reading and writing technical documents and talking with lawyers, but I tend to keep conversations in context, at least in regard to the OP's question(s). Since the OP didn't mention modifying upper/lower mounts, I think it safe to assume that he's talking about a balanced setup, typical of a TJ, on stock geometry and within the confines of stock shock mount locations, or did I read this wrong? (wouldn't be the first time )
To this, it seems that the only realized benefit is to have the ability to run typical 11" travel shock, at or near-factory bias of 4.5"-5" of up and 6.5-6" down, with lower lift and less additional bumpstop length - or alternatively - gives the ability to run common lift height springs for 35"s (3.5-4") with longer-than-typical shocks (though not considerably more since you start running into other issues). Would this be an accurate statement??
For my eyes - it's about tire-to-lift ratio. My 35"s seem a tad undersized (depends on the angle) with my GR Hi-Fenders (and unlike BFGs and some others, these Grabbers are actually fairly close to 35") and 3.5" springs.I wonder if there’s a minimum tire size for highlines / aluminum’s to look good.
I like the look, but will the 3 Inch lift give you enough flex w/ 35’s when you hit the dirt?For my eyes - it's about tire-to-lift ratio. My 35"s seem a tad undersized (depends on the angle) with my GR Hi-Fenders (and unlike BFGs and some others, these Grabbers are actually fairly close to 35") and 3.5" springs.
Ideally I would run a 2" spring on 35"s or the 3-3.5" springs on 37"s for a very "balanced look". I have some future mods planned that will allow proper utilization of the extra space, but with a family move planned in spring/early-summer of 2021, I will have my hands full getting the paint job and Hemi/auto-conversion done with enough time to get our stuff packed up!
Two things to think about. 3" is about 2" less than the typical recommendation of a 4" spring, 1.25" body lift. The lower spring lift also doesn't allow for as long of shocks, meaning there is less flex compared to the typical recommendation for 35s.I like the look, but will the 3 Inch lift give you enough flex w/ 35’s when you hit the dirt?
Yeah, your gonna hit the shock before the wheel, bummer.Two things to think about. 3" is about 2" less than the typical recommendation of a 4" spring, 1.25" body lift. The lower spring lift also doesn't allow for as long of shocks, meaning there is less flex compared to the typical recommendation for 35s.
Add that all up and now factor in the added clearance of a highline.
Yeah I have a 4” suspension with a 1.25” body lift. , so a little differentFor my eyes - it's about tire-to-lift ratio. My 35"s seem a tad undersized (depends on the angle) with my GR Hi-Fenders (and unlike BFGs and some others, these Grabbers are actually fairly close to 35") and 3.5" springs.
Not even close to each otherHow is the clearance on these vs MetalCloak arched I wonder...
Well now you have me intrigued so I'll play along with the Guessing Game to see if my understanding of the TJ suspension/limitations is moving in the right direction...Mine is a fairly typical 35s build with a 10.75" travel front shock with just under 6" of up travel. One important difference is that the front upper shock mounts are raised a little over an inch, meaning my tire can stuff a little higher than a stock shock mount.
What good would highlines get me? There is a real answer to that question. But it isn't what most would think it is because it has little to do with the top of the tire.
In these pics I’m on the bump stop on the driver side (I have about 1/2” of shock shaft remaining so I can trim some more) and on the passenger side the spring (a 3.5” RK triple rate) is loose in the bucket (it had dropped completely from the bucket at points on this trail).I like the look, but will the 3 Inch lift give you enough flex w/ 35’s when you hit the dirt?
