The TB bracket helps to restore the side to side geometry of the TB after a lift, but I suppose you get get away without it in the short term if you get an adjustable TB. You'll need to get the angled TB relocation bracket anyway after the SYE to keep the rear TB from hitting the gas tank skid because you will be raising the pinion angle to match the new Double cardan drive shaft angle.
