Got an issue, I was driving on the freeway totally fine for about 45 minutes, took an exit, and when I slowed down the engine lost all power, exhaust started banging, kept flooring it didn't do anything, eventually, it finally revved up, then it drove fine for 1/4 mile till I slowed down and it did it again as seen in the video, the same thing happened a third time.
Started it up again and it seemed to be fine, towed it home and it drives fine cold and warmed up, haven't driven it far but the engine sounds great and the exhaust sounds fine.
It drives fine now, haven't driven it far because it will probably happen again.
99 TJ auto 4.0
pulled Code p1391-loss of cam or crank signals.
not sure if this is related. my check engine light does not work so it could be an old code.
Here is a video I uploaded showing what happened
99 TJ auto 4.0
