Michigan Jeep Manual Transmission to VW CJAA/CBEA TDI Diesel Swap Parts
Sea Cot
S.E. MI
Price
2500
New Boston, MI 48164
Apologies for the acronym-ridden title. . . . The donor engine came from my son's '09 Jetta (auto) which was deleted and had Malone 2.0 tune. The modded version achieved 45-55mpg and was a hoot to drive. I believe the OEM head bolts stretched/head lifted or the head gasket failed which lead to pulling the car apart. The issue was identified before overheating could occur. The car did not overheat. It failed the exhaust gas in the coolant test. I decided replace the car rather than repair it.
The TDI's modded form would be an absolute riot in a TJ. I don't want to take the '98 Sport off-line for this mod.
Selling as a package. Will split only in this order:
  1. all used parts in one bundle
  2. all new parts as a whole (after used parts are gone)
  3. new parts separately (after used parts are gone)
More pics to come when I get around to it. . .
New in box parts not installed:
  • Whitbread Performance VW 4 Cylinder to Jeep 4.0L w/ MANUAL trans Adapter Kit: LINK
  • Whitbread Performance BRM/CBEA/CJAA Oil Cooler Housing Relocation Plate w/ CVR remote oil filter head option. LINK
  • Diesel Geek high Mileage Timing Kit LINK
  • Diesel Geek/Metal Nerd Timing Tool Set for 2009-2014 TDI LINK
  • Mr. Gasket electric diesel fuel pump LINK
  • A plethora of parts from ID Parts: Cylinder head install kit, intake manifold gasket, exhaust manifold gasket, 2-hole head gasket, valve cover gasket, vacuum pump seal, oil filter flange gasket, oil cooler gasket set, fuel injector plates, injector tensioning plate, camshaft seal, crankshaft seal
Used parts from the '09.
  • Assembled short block. 20k miles on oil shaft balancer installed by local VW dealer under Dieselgate warranty. The short block has been cleaned up with a needle scaler & brush. Haven't gotten around to painting it yet. The
  • Cylinder head- passed pressure testing at the local machine shop
  • OEM turbo manifold replaced 20k miles ago by local VW dealer under Dieselgate warranty
  • ECU w/ Malone 2.0 tune. IIRC, the immobilizer is still on/active
  • Whitbread CR TDI lower timing belt cover (installed) LINK
  • Alternator w/ clutch pulley replaced ~10k miles ago, plus other front engine accessories
  • Engine harness with "generous" portion of body/dash. I don't recall flush-cutting this at the firewall
  • accelerator petal, instrument cluster, fuel injectors, glow plugs, etc..
Extras:
  • VCDS for the ECU, two VINs available
  • Jetta hardcover service manual
Reactions: Desert Roamer
