I just replaced my factory sub with a pyramid sub, plugged it back in to test it. Nothing happened, does anyone have any suggestions?
If you can, return it. Buy this instead: https://www.crutchfield.com/p_777B8...a&awnw=g&awcr=48387319825&awdv=m&awug=9003557
At the time, when I bought it, a wiring kit was free. Looks like you'll have to purchase it, but I think it's fairly cheap. Either way, I cannot rant enough on how amazing (especially for a TJ) this thing makes my audio sound.
Gut the internal amp that you have in the console and install this thing. Basically, it'll sit up on its side, inside the center console.
For not much more $ you can get the Rockford Fosgate PS-8. Same kind of deal as the Sound Ordnance, but better quality. Some get solid performance out of the SO but others not so much. Crutchfield has great customer service, so they would probably replace it if it was a problem, but I just went with the Rockford Fosgate and couldn't be happier.
https://www.amazon.com/dp/B00Y3WKUX8/?tag=wranglerorg-20
You wouldn't be disappointed. You'll have kicked yourself for not doing it sooner! No support through Amazon but I can walk you through install if you need help.Hmmm, I might snag one of those! I hadn't seen that until now, thanks for the link.
X2You wouldn't be disappointed. You'll have kicked yourself for not doing it sooner! No support through Amazon but I can walk you through install if you need help.
Does this sound like a "sub"? I have a PO installed amp and sub that is taking up my whole trunk area. It sounds great but I hate the storage in my Jeep. After reading some reviews for awhile it sounds like this is the way to go. Another item on the list, does it ever end?If you can, return it. Buy this instead: https://www.crutchfield.com/p_777B8...a&awnw=g&awcr=48387319825&awdv=m&awug=9003557
I may take you up on that! I'm not worried about no support through Amazon. I'm pretty smart, and with you to possibly guide me, I think I'll have it covered!
Muchas gracias! I'll let you know if I run into any issues.You should have no problem, just wanted to offer my service since you serve us so well. Thanks Chris!
If you get it, only things you need that aren't included; 2 ring connectors (one for battery terminal, one for ground), and IF you have pre-amp outs on the back of your head unit, and preferably a sub pre-amp out, and intend to send the signal to the amp that way (recommended), THEN you need a set of RCA's long enough to reach the amp. Then you'll be ready when it arrives.Muchas gracias! I'll let you know if I run into any issues.
It's not gonna rattle your teeth but for me it's perfect.Does this sound like a "sub"? I have a PO installed amp and sub that is taking up my whole trunk area. It sounds great but I hate the storage in my Jeep. After reading some reviews for awhile it sounds like this is the way to go. Another item on the list, does it ever end?
