This is my second TJ and first one with a lift and 6 cyl. The original owner put a Teraflex 3" lift and 9550 shocks on it at 30 original miles per carfax report. No further documentation. Car now has 46,000 miles and ride is a little wonky side to side over certain stuff and when I hit more than a bump it gets squirrelly. Otherwise it rides nice on flat surface. I decide its best to put in new shocks and jump into the 10k forum posts on the subject . Having measured my ride height springs front and rear I get 15.25 Front and 12 rear. This means a 3.25" front lift and 4" rear lift when stock is 12 F / 8 R respectively. Now I check the 9550 shocks and the model # on their site says for 2-3" lift front and rear. Ok now I'm scratching my cockeyed head. Looks like I have all stock control arms which is the beginning of my question as going over 3" says I need upgrade other components like control arms. Currently not in the budget and if it's been fine for 46k it should be fine with just new shocks.
Should I just get Bilstein 5100 3" all the way around or should I go 3" up front and 3.5-4" in the rear from Bilstein?
LMK if you need more information. Appreciate any help. Trying not to overthink this.
