Jeep TJ crank but no start (SKIM?)
Moore_77373
Alberta
Hey all, I’m at a loss as to what’s wrong with my Jeep.
It started a few days ago when I was letting it idle before I left to go out & it randomly started misfiring, sputtering before it eventually stopped running. I tried starting it again & it would sputter for a few seconds before once again dying.
Eventually it stopped starting altogether.
It threw code P1282 - “Fuel Pump Relay Control Circuit An open or shorted condition detected in the fuel pump relay control circuit.”
I thought maybe I could jump the fuel pump relay but all that would do is cause It to fire & it would almost start. But it wouldnt actually start. (Improvement I guess lol)
But now the SKIM light is flashing whenever I try to turn the motor over or leave it in the run position. I’m completely at a loss & have no clue what’s wrong any ideas?
hear
Prosper, TX
I don’t own a pressure tester so I don’t know
You should be able to borrow/rent one from the parts store, unless they don't have those up in Yellowknife. :). The SKIM will let it start but will kill it shortly after it starts. It doesn't sound like SKIM is your issue.
