Jeep TJ Soft Top Install Question
gjandy
USA
Can someone explain the mechanism behind the Side Bow for my Rampage Soft Top? There's a pivot point on each end, however, it then gets attached to the Door Surround on top and the Bow Assembly Bracket on the side. If you take an item with two pivot points, but attach it to two points that don't move, then the Side Bow can't move. And if the Side Bow doesn't move, how do you fold down the soft top?
It turns out to be a frame kit that is not able to go down. I had no idea anyone would want that, so it never dawned on me that there would be a soft top that was fixed in place. Thanks for those who reached out to try and help. To the person who wondered why I started a new topic to ask the same question: I did that to ask my question in a better way, and to try and be more concise and clear to enable an answer.
