So I just bought another TJ (98 Sahara 4.0l 3spd automatic) and it sat for a little over a year battery was dead before it sat but would start and run rough. Fast forward now I’ve started to work on it and I have replaced: Battery, crank sensor, cam sensor, coil, distributor, wires, plugs, new 2ga ground & power cables, & battery terminals (as well as tons of other stuff not related to starting) any way, it still won’t start so I tried starter fluid to see if it would try and nothing. Then I put a plug in the feed wire for the distributor to see if it had power and nope none. I broke out the code reader and it won’t connect to computer. The other odditie is the gas and voltage gauges don’t register anything. I’m at my wits end anyone have a wiring diagram for starting side or any ideas where I should go???? Any help is greatly appreciated. Thanks.
