Hoping someone can point me in the right direction here. So to give the full story the Jeep had been giving me an small evap leak code for the 5 months I've owned it, and an occasional crankshaft position sensor code. I got in a bad habit of clearing them and continuing on down the road. Two weeks ago after a longer drive (around 200 miles round trip) the CEL lights wouldn't stay off for longer than 5 minutes so I decided it's time to actually fix the issues. I go to start the Jeep to move it into the garage to work on it and it won't start, making a lot of loud what sounds like air being released fast, choking noises, I fiddle with a few of the connections, see if they are tight to the crankshaft POS sensor, the TPS, and when I got around to the camshaft position sensor notice that it would spin 180° and the hold down bolt was lose. I turn it the way I thought it was originally (plug facing can) and it fires up. I drove it around town, mainly to charge the battery back up from cranking on it over the previous day's, and on my way home it bogs down, eventually killing. Starts back up, and was able to limp it back home. This weekend I've replaced, the TPS, the crankshaft position sensor, cleaned the IAC valve, and just today the camshaft position sensor, all with factory OEM Mopar sensors with the exception of the camshaft position sensor which I couldn't find OEM so I used Napa Echlin one. The Jeep seems much harder to start now, sputters and dies giving me codes for all the sensors that I just barely replaced. I've got the following codes P0340, P0123, P0352, P1391, P1391 PD. I am so frustrated as I was hoping all these brand new Mopar Sensors would make this thing run like a top. The only thing that I can think of is that I didn't get the Camshaft position assembly in at the right angle, is there anyway to tell which way the "slot" down inside there should be pointing i.e. side to side with the Jeep? Front to back with the Jeep? I had to get a flashlight and look down in there and it was on like a 45 degree angle, so I turned the piece that I was installing,to match so it would fully seat, tightened down the hold down ring, plugged it in and now it will hardly start at all, if it does it will sputter right out and throw all codes again. I should mention that I did take off the positive battery terminal, hold it on the negative for about 60 seconds, hooked it back up, turned the key on, headlights on, headlights off, key off right after I switched all the sensors. I am wondering if it's out of timing from the OPDA being lose for who knows how long. I have no idea how to check that. The teeth on the OPDA do not appear to be scarred hardly at all. No metal shavings ect. Any help would be awesome, I have several vehicles, don't need the Jeep, but it's my favorite one to drive,
