Hi everyone. I’ve spent the last couple days reading through posts and trying to fix my jeep but haven’t figured it out yet so I was hoping to get some help from y’all.
I went to start my jeep and I got one click but no crank. All the lights, radio, and headlights come on and do not dim. I pushed it up a hill then rolled it down and popped the clutch to get it home. It ran for an hour with no problems. It wouldn’t start again once I was home and turned it off. I took my multimeter and checked the battery in both key positions and the battery was great. Next I swapped fuses under the hood and in the glove box to see if it was a fuse or the clutch safety. None of those worked. I then checked the power going to the main post on my starter and had power there. I used a screwdriver and was able to get the starter to turn. I then connected a female quick disconnect to a wire and attached it to the starter and ran the wire up to the battery. The starter would spin but I could not get it to start.
Do y’all think it is the ignition actuator or the ignition switch?
2004 Jeep Wrangler Rubicon with the 4.0 and manual transmission.
Thanks you
Thanks you
