As some of you know, I sold my 98TJ because it didn't fit my needs for carrying as much as my Cherokee did. Having said that, I'm still looking for a Cherokee, but I have come to the conclusion that I really don't want one, so I'm looking for another TJ. I will make it work. Ya don't know what you've got till it's gone and all of that.
Anyway.... Sunday I went to look at TJ #1. All went well till I looked under the frame where it goes from the passenger side floor up under where the passenger's feet would be. I found a rotted hole, patched with fiberglass and covered with undercoating. From normal driving and hitting bumps and potholes and whatnot, the hole had turned into cracking around half the perimiter of the frame. The seller was less than pleased when I informed them of the issues. I passed on that one.
TJ#2 was Monday. The rear of the frame on both sides where it goes up parallel to the sides of the gas tank, had rotted out. It had been filled with foam, like Great Stuff spray foam, smoothed over with caulk, then covered with undercoating. It was hard to see till I saw it, then it was quite obvious. I passed on that one too.
AAAAARRRRRGGGGGGHHHHHHH!!!!!
Why not just get the frame welded by a pro and the frame will be safe to drive and sell?
Rant over.
Back to your normally scheduled programming.
Thank you for letting me vent.
KenR955
Rant over.
KenR955
