ok makes sense maybe it is time i warm up my clamp tite tool. i believe it is a constant tension clamp
www.clamptitetools.com
If the Dorman 620-112 bolts up to the stock fan clutch, which I believe from posts on JF it does, is it an improvement over the stock 5 blade? Are there any negatives to the 9 blade swap?
https://www.amazon.com/dp/B000C122US/?tag=wranglerorg-20
That thing is awesome!ok makes sense maybe it is time i warm up my clamp tite tool. i believe it is a constant tension clamp
So, I see 5012366AF for my 2004 jeep wrangler 4.0 Liter at amazon is $337.59, but I see a replacement part number of 68382492AA on wermopar.com ($135.72) & tascaparts.com ($134.56). Can someone confirm if this replacement part number of 68382492AA is correct? Also does anyone know what the Mopar part number is to replace the metal heater line (See Below I). Possibly 53007978? 53007978 doesn’t look like below I to me. I appreciate any help!
I. Dorman 56398
https://www.amazon.com/dp/B001C6JCU0/?tag=wranglerorg-20
Yeah, the dorman part looks correct, but when I look at Mopar 53007978 in the diagram it doesn’t look right. Almost looks small but looking at some other sites. The real/color PIC's look correct. Maybe the Mopar diagram just shows it shorter with the part number 53007978. Mine is badly rusted and I thought I might replace it. I'd like to buy the Mopar one if possible but wasn’t a 100% sure on the part number. I'll try 53007978 and see what I get.
Adding HOAT Antifreeze link to thread. Previous one in this thread is broken. Found it in another thread in this forum. 10 year/150,000 miles 50/50.
https://www.amazon.com/dp/B017DP43ZC/?tag=wranglerorg-20
6 Cylinder Models:
1997-1999 (4.0 liter 6 cylinder)
Waterpump: 4626054AF
Thermostat: 52028186AC
Thermostat Gasket
Radiator: 55037652AA (Manual Transmission)
Radiator: 55037653AB (Automatic Transmission)
Upper Radiator Hose: 52028264AB
Lower Radiator Hose: 52079670AA
Fan Clutch: 68065080AA
Replacement Radiator Cap: Stant #10234 (yes, this part is a must if you're refreshing your cooling system)
Is this water pump part number correct? When I look it up on a different website it shows a different Mopar pump that is $160 where the one above is only $50....what I’m getting is Mopar pump 68382489AA....can anyone verify if the one in this write up is okay to get for a 99?
Yes, I'm 110% certain that is the correct water pump part number. See here:
https://www.wermopar.com/oem-parts/mopar-water-pump-assembly-68382489aa
That part number was just superseded with a newer part number, that's all.
I used the link in the original post for the Mopar coolant but after doing a little reading it looks like that Mopar coolant in the link is OAT not HOAT....is that correct? I ask because the write up said get a HOAT
Rather than the Mopar brand, many TJ owners use Valvoline Zerex G-05, a quality HOAT coolant available at nearly every parts store:
I have a 97 4 cylinder, and every part store I've been to has had the wrong numbers for the heater hoses. Got PO'd and just used bulk hoses
