Great writeup and convinced me to upgrade to Truck-Lites.
Thank you for the research and posting!
One typo in the original post I'd like to point out though because it was sort of confusing. . .
"Are Jeep Wrangler TJ headlights the same as JK LED headlights?
Aside from the harness these headlights use to plug-in, there is no difference at all in terms of fitment. In other words, a JK headlight is the same as a TJ headlight, with the exception of the wiring harness. If a headlight mentions that it was designed for the Jeep Wrangler TJ, all you need to make it work with your TJ is some H4 to H13 adapters. I've noted next to most of these headlights which if they'll require the adapters or not. These adapters will allow for any JK headlight to be a simple plug-and-play installation, taking about 5-10 minutes per headlight to install at most."
I think the bolded sentence below the section header was meant to read: "If a headlight mentions that it was designed for the Jeep Wrangler JK, all you need to make it work with your TJ are some H4 to H13 adapters."
