Has anyone tried the SPL Classic 7 inch Cree chips LED headlights from Amazon? They were noted as being Amazon’s Choice in led headlights and have good reviews?
What name brand are they copying?Looks the same as every other Chinese version out there, nothing different about them.
That's not to say they are bad of course.
Well I ordered them and have them installed. I haven't drove at night yet. I did try to adjust them down some in my garage during the day. What does the adjustment screw at 7 o'clock do? I read your write up on adjusting the headlights but didn't see that screw mentioned.
I just remembered the seller gave me a Haynes Repair Manual for 1987-2003 Jeep Wranglers, so I looked up adjusting headlights. It says the screw at 2 o’clock is for up/down and the one at 7-8 o’clock is for left/right. There is one at 4 o’clock but it doesn’t say what it is for.I'm not sure, but I think that's just a mounting screw for the headlight bucket.
After installing the headlights I was trying to adjust them before putting the trim rings on because I knew you would have more room to get to the adjusting screws. It seems the beam pattern on my lights are wide and I can’t determine what the center of the beam is. So I gave up for now and put the trim rings on. Now I see where the adjustment indentations are on my rings and on the drivers side they are at 2 o’clock and 8 o’clock and on the passenger side they are at 10 o’clock and 4 o’clock.I'm not sure, but I think that's just a mounting screw for the headlight bucket.
FWIW, I set mine up so that the upper and lower LEDS illuminate as soon as you turn the Jeep on. Not sure how much light you need to meet the law, but even just the 2 small LED strips light up my driveway.Can anyone comment on what do these LED's headlights do with the DRL option? I know the Canadian Jeep market has DRL's when you move a foot or so the headlights come on. Is this function gone when one of these LED headlights is installed?
My CPL Classics at nightWould be nice if people that install these Chinese lights also post pics so we see which lights they are..
Which headlights are you referring to? The ones that have the high/low beam split between the upper and lower half? Or some other type?
I'm torn between these two sets, not sure..
