Jeep Wrangler TJ OBDII Scan Code Guide
Chris
Administrator
Staff Member
Gillette, WY
Having trouble with your Jeep Wrangler TJ or LJ? Scan it with an OBDII reader, pull the code, and use the table below to identify the potential issue.
Scan CodeProblemDescription
P0030
1/1 O2 Sensor Heater Relay Circuit
Problem detected in oxygen sensor heater relay circuit.
P0036
1/2 O2 Sensor Heater Relay Circuit
P0106
Barometric Pressure Out of Range
MAP sensor input voltage out of an acceptable range detected during reading of barometric pressure at key-on.
P0107
Map Sensor Voltage Too Low
MAP sensor input below minimum acceptable voltage.
P0108
Map Sensor Voltage Too High
MAP sensor input above maximum acceptable voltage.
P0112
Intake Air Temp Sensor Voltage Low
Intake air (charge) temperature sensor input below the minimum acceptable voltage.
P0113
Intake Air Temp Sensor Voltage High
Intake air (charge) temperature sensor input above the maximum acceptable voltage.
P0116
No Message
A rationality error has been detected in the coolant temp sensor.
P0117
ECT Sensor Voltage Too Low
Engine coolant temperature sensor input below the minimum acceptable voltage.
P0118
ECT Sensor Voltage Too High
Engine coolant temperature sensor input above the maximum acceptable voltage.
P0121
TPS Voltage Does Not Agree With MAP
TPS signal does not correlate to MAP sensor signal.
P0121
Accelerator Position Sensor (APPS) Signal Voltage Too Low
APPS voltage input below the minimum acceptable voltage.
P0122
Throttle Position Sensor Voltage Low
Throttle position sensor input below the acceptable voltage range.
P0122
P0123
Throttle Position Sensor Voltage High
Throttle position sensor input above the maximum acceptable voltage.
P0123
Accelerator Position Sensor (APPS) Signal Voltage Too High
APPS voltage input above the maximum acceptable voltage.
P0125
Closed Loop Temp Not Reached
Time to enter Closed Loop Operation (Fuel Control) is excessive.
P0125
Engine is Cold Too Long
Engine does not reach operating temperature.
P0130
1/1 O2 Sensor Heater Circuit Malfunction
Oxygen sensor heater element malfunction.
P0131
1/1 O2 Sensor Shorted To Ground
Oxygen sensor input voltage maintained below normal operating range.
P0132
1/1 O2 Sensor Shorted To Voltage
Oxygen sensor input voltage maintained above normal operating range.
P0133
1/1 O2 Sensor Slow Response
Oxygen sensor response slower than minimum required switching frequency.
P0134
1/1 O2 Sensor Stays at Center
Neither rich or lean condition is detected from the oxygen sensor input.
P0135
1/1 O2 Sensor Heater Failure
P0136
1/2 O2 Sensor Heater Circuit Malfunction
P0137
1/2 O2 Sensor Shorted To Ground
P0138
1/2 O2 Sensor Shorted To Voltage
P0139
1/2 O2 Sensor Slow Response
P0140
1/2 O2 Sensor Stays at Center
Neither rich or lean condition is detected from the oxygen sensor.
P0141
1/2 O2 Sensor Heater Failure
P0143
P0144
P0145
P0146
P0147
P0151
2/1 O2 Sensor Shorted To Ground
P0152
2/1 Sensor Shorted To Voltage
P0153
2/1 Sensor Slow Response
P0154
2/1 Sensor Stays at Center
P0155
2/1 O2 Sensor Heater Failure
P0157
2/2 O2 Sensor Shorted To Ground
P0158
2/2 O2 Sensor Shorted To Voltage
P0159
2/2 Sensor Slow Response
P0160
2/2 Sensor Stays at Center
P0161
2/2 O2 Sensor Heater Failure
P0168
Decreased Engine Performance Due To High Injection Pump Fuel Temp
Fuel temperature is above the engine protection limit. Engine power will be derated.
P0171
1/1 Fuel System Lean
A lean air/fuel mixture has been indicated by an abnormally rich correction factor.
P0172
1/1 Fuel System Rich
A rich air/fuel mixture has been indicated by an abnormally lean correction factor.
P0174
2/1 Fuel System Lean
P0175
2/1 Fuel System Rich
P0176
Loss of Flex Fuel Calibration Signal
No calibration voltage present from flex fuel sensor.
P0177
Water In Fuel
Excess water found in fuel by water-in-fuel sensor.
P0178
Flex Fuel Sensor Volts Too Low
Flex fuel sensor input below minimum acceptable voltage.
P0178
Water In Fuel Sensor Voltage Too Low
Loss of water-in-fuel circuit or sensor.
P0179
Flex Fuel Sensor Volts Too High
Flex fuel sensor input above maximum acceptable voltage.
P0181
Fuel Injection Pump Failure
Low power, engine derated, or engine stops.
P0182
CNG Temp Sensor Voltage Too Low
Compressed natural gas temperature sensor voltage below acceptable voltage.
P0183
CNG Temp Sensor Voltage Too High
Compressed natural gas temperature sensor voltage above acceptable voltage.
P0201
Injector #1 Control Circuit
An open or shorted condition detected in control circuit for injector #1 or in the INJ 1 injector bank.
P0202
Injector #2 Control Circuit
An open or shorted condition detected in control circuit for injector #2 or in the INJ 2 injector bank.
P0203
Injector #3 Control Circuit
An open or shorted condition detected in control circuit for injector #3 or in the INJ 3 injector bank.
P0204
Injector #4 Control Circuit
Injector #4 or INJ 4 injector bank output driver stage does not respond properly to the control signal.
P0205
Injector #5 Control Circuit
Injector #5 output driver stage does not respond properly to the control signal.
P0206
Injector #6 Control Circuit
Injector #6 output driver stage does not respond properly to the control signal.
P0207
Injector #7 Control Circuit
Injector #7 output driver stage does not respond properly to the control signal.
P0208
Injector #8 Control Circuit
Injector #8 output driver stage does not respond properly to the control signal.
P0209
Injector #9 Control Circuit
Injector #9 output driver stage does not respond properly to the control signal.
P0210
Injector #10 Control Circuit
Injector #10 output driver stage does not respond properly to the control signal.
P0215
Fuel Injection Pump Control Circuit
Failure in fuel pump relay control circuit
P0216
Fuel Injection Pump Timing Failure
High fuel supply restriction, low fuel pressure or possible wrong or incorrectly installed pump keyway.
P0217
Decreased Engine Performance Due To Engine Overheat Condition
Engine overheating. ECM will derate engine performance.
P0219
Crankshaft Position Sensor Overspeed Signal
Engine has exceeded rpm limits.
P0222
Idle Validation Signals Both Low
Problem detected with idle validation circuits within APPS.
P0223
Idle Validation Signals Both High (Above 5 Volts)
P0230
Transfer Pump (Lift Pump) Circuit Out of Range
Problem detected in fuel transfer pump circuits.
P0232
Fuel Shutoff Signal Voltage Too High
Fuel shut-off signal voltage too high from ECM to fuel injection pump.
P0234
Turbo Boost Limit Exceeded
Problem detected in turbocharger wastegate.
P0236
Map Sensor Too High Too Long
P0237
MAP sensor voltage input below the minimum acceptable voltage.
P0238
MAP sensor voltage input above the maximum acceptable voltage.
P0251[br /]
Fuel Inj. Pump Mech. Failure Fuel Valve Feedback Circuit
Problem sensed with fuel circuit internal to fuel injection pump.
P0253
Fuel Injection Pump Fuel Valve Open Circuit
P0254
Fuel Injection Pump Fuel Valve Current Too High
Problem caused by internal fuel injection pump failure.
P0300
Multiple Cylinder Mis-fire
Misfire detected in multiple cylinders.
P0301
CYLINDER #1 MISFIRE
Misfire detected in cylinder #1.
P0302
CYLINDER #2 MISFIRE
Misfire detected in cylinder #2.
P0303
CYLINDER #3 MISFIRE
Misfire detected in cylinder #3.
P0304
CYLINDER #4 MISFIRE
Misfire detected in cylinder #4.
P0305
CYLINDER #5 MISFIRE
Misfire detected in cylinder #5.
P0306
CYLINDER #6 MISFIRE
Misfire detected in cylinder #6.
P0307
CYLINDER #7 MISFIRE
Misfire detected in cylinder #7.
P0308
CYLINDER #8 MISFIRE
Misfire detected in cylinder #8.
P0309
CYLINDER #9 MISFIRE
Misfire detected in cylinder #9.
P0310
CYLINDER #10 MISFIRE
Misfire detected in cylinder #10.
P0320
No Crank Reference Signal at PCM
No reference signal (crankshaft position sensor) detected during engine cranking.
P0320
No RPM Signal to PCM (Crankshaft Position Sensor Signal to JTEC)
A CKP signal has not been detected at the PCM.
P0325
Knock Sensor #1 Circuit
Knock sensor (#1) signal above or below minimum acceptable threshold voltage at particular engine speed.
P0330
Knock Sensor #2 Circuit
Knock sensor (#2) signal above or below minimum acceptable threshold voltage at particular engine speed.
P0336
Crankshaft Position (CKP) Sensor Signal
Problem with voltage signal from CKP.
P0340
No Cam Signal At PCM
No fuel sync.
P0341
Camshaft Position (CMP) Sensor Signal
Problem with voltage signal from CMP.
P0350
Ignition Coil Draws Too Much Current
A coil (1-5) is drawing too much current.
P0351
Ignition Coil # 1 Primary Circuit
Peak primary circuit current not achieved with maximum dwell time.
P0352
Ignition Coil # 2 Primary Circuit
P0353
Ignition Coil # 3 Primary Circuit
P0354
Ignition Coil # 4 Primary Circuit
Peak primary circuit current not achieved with maximum dwell time (High Impedence).
P0355
Ignition Coil # 5 Primary Circuit
P0356
Ignition Coil # 6 Primary Circuit
Peak primary circuit current not achieved with maximum dwell time (high impedence).
P0357
Ignition Coil # 7 Primary Circuit
P0358
Ignition Coil # 8 Primary Circuit
P0370
Fuel Injection Pump Speed/Position Sensor Sig Lost
P0380
Intake Air Heater Relay #1 Control Circuit
Problem detected in #1 air heater solenoid/relay circuit (not heater element)
P0381
Wait To Start Lamp Inoperative
Problem detected in wait-to-start bulb circuit.
P0382
Intake Air Heater Relay #2 Control Circuit
Problem detected in #2 air heater solenoid/relay circuit (not heater element)
P0387
Crankshaft Position Sensor Supply Voltage Too Low
CKP sensor voltage input below the minimum acceptable voltage.
P0388
Crankshaft Position Sensor Supply Voltage Too High
CKP sensor voltage input above the maximum acceptable voltage.
P0401
EGR System Failure
Required change in air/fuel ration not detected during diagnostic test.
P0403
EGR Solenoid Circuit
An open or shorted condition detected in the EGR solenoid control circuit.
P0404
EGR Position Sensor Rationality
EGR position sensor signal does not correlate to EGR duty cycle.
P0405
EGR Position Sensor Volts Too Low
EGR position sensor input below the acceptable voltage range.
P0406
EGR Position Sensor Volts Too High
EGR position sensor input above the acceptable voltage range.
P0412
Secondary Air Solenoid Circuit
An open or shorted condition detected in the secondary air (air switching/aspirator) solenoid control circuit.
P0420
1/1 Catalytic Converter Efficiency
Catalyst 1/1 efficiency below required level.
P0432
1/2 Catalytic Converter Efficiency
Catalyst 2/1 efficiency below required level.
P0441
Evap Purge Flow Monitor
Insufficient or excessive vapor flow detected during evaporative emission system operation.
P0442
Evap Leak Monitor Medium Leak Detected
A small leak has been detected in the evaporative system.
P0443
Evap Purge Solenoid Circuit
An open or shorted condition detected in the EVAP purge solenoid control circuit.
P0455
Evap Leak Monitor Large Leak Detected
A large leak has been detected in the evaporative system.
P0456
Evap Leak Monitor Small Leak Detected
Leak has been detected in the evaporative system.
P0460
Fuel Level Unit No Change Over Miles
During low fuel.
P0460
Fuel level sending unit voltage does not change for more than 40 miles.
P0462
Fuel Level Sending Unit Volts Too Low
Fuel level sensor input below acceptable voltage.
P0462
Open circuit between PCM and fuel gauge sending unit.
P0463
Fuel Level Sending Unit Volts Too High
Fuel level sensor input above acceptable voltage.
P0463
Circuit shorted to voltage between PCM and fuel gauge sending unit.
P0500
No Vehicle Speed Sensor Signal
No vehicle speed sensor signal detected during road load conditions.
P0500
A vehicle speed signal was not detected.
P0505
Idle Air Control Motor Circuits
SBEC II
P0522
Oil Pressure Voltage Too Low
Oil pressure sending unit (sensor) voltage input below the minimum acceptable voltage.
P0523
Oil Pressure Voltage Too High
Oil pressure sending unit (sensor) voltage input above the maximum acceptable voltage.
P0524
Oil Pressure Too Low
Engine oil pressure is low. Engine power derated.
P0545
A/C Clutch Relay Circuit
Problem detected in air conditioning clutch relay control circuit.
P0551
Power Steering Switch Failure
Incorrect input state detected for the power steering switch circuit. PL: High pressure seen at high speed.
P0562
Charging System Voltage Too Low
Supply voltage sensed at ECM too low.
P0563
Charging System Voltage Too High
Supply voltage sensed at ECM too high.
P0600
PCM Failure SPI Communications
No communication detected between co-processors in the control module.
P0601
Internal Controller Failure
Internal control module fault condition (check sum) detected.
P0602
ECM Fueling Calibration Error
ECM Internal fault condition detected.
P0604
RAM Check Failure
Transmission control module RAM self test fault detected. -Aisin transmission
P0605
ROM Check Failure
Transmission control module ROM self test fault detected. -Aisin transmission
P0606
ECM Failure
P0615
Starter Relay Control Circuit
An open or shorted condition detected in the starter relay control circuit.
P0622
Generator Field Not Switching Properly
An open or shorted condition detected in the generator field control circuit.
P0645
An open or shorted condition detected in the A/C clutch relay control circuit.
P0700
EATX Controller DTC Present
This SBEC III or JTEC DTC indicates that the EATX or Asin controller has an active fault and has illuminated the MIL via a CCD (EATX) or SCI (Aisin) message. The specific fault must be acquired from the EATX via CCD or from the Aisin via ISO-9141.
P0703
Brake Switch Stuck Pressed or Released
Incorrect input state detected in the brake switch circuit. (Changed from P1595)
P0711
Trans Temp Sensor, No Temp Rise After Start
Relationship between the transmission temperature and overdrive operation and/or TCC operation indicates a failure of the Transmission Temperature Sensor. OBD II Rationality. Was MIL code 37.
P0712
Trans Temp Sensor Voltage Too Low
Transmission fluid temperature sensor input below acceptable voltage. Was MIL code 37.
P0712
Voltage less than 1.55 Volts (4-speed auto. trans. only)
P0713
Trans Temp Sensor Voltage Too High
Transmission fluid temperature sensor input above acceptable voltage. Was MIL code 37.
P0713
Voltage greater than 3.76 volts (4-speed auto. trans. only).
P0720
Low Output SPD Sensor RPM, Above 15 mph
The relationship between the Output Shaft Speed Sensor and vehicle speed is not within acceptable limits.
P0720
Low Output Spd Sensor RPM Above 15 mph
Output shaft speed is less than 60 rpm with vehicle speed above 15 mph (4-speed auto. trans. only).
P0740
Torq Con Clu, No RPM Drop at Lockup
Relationship between engine and vehicle speeds indicated failure of torque convertor clutch lock-up system (TCC/PTU solenoid)
P0743
Torque Converter Clutch Solenoid/ Trans Relay Circuits
An open or shorted condition detected in the torque convertor clutch (part throttle unlock) solenoid control circuit. Shift solenoid C electrical fault - Asin transmission
P0743
An open or shorted condition detected in the torque convertor part throttle unlock solenoid control circuit (3 or 4-speed auto. trans. only).
P0748
Governor Pressure Sol Control/Trans Relay Circuits
An open or shorted condition detected in the Governor Pressure Solenoid circuit or Trans Relay Circuit in JTEC RE transmissions.
P0748
An open or shorted condition detected in the governor pressure solenoid or relay circuits (4-speed auto. trans. only).
P0751
O/D Switch Pressed (Lo) More Than 5 Minutes
Overdrive override switch input is in a prolonged depressed state.
P0751
O/D Switch Pressed (LO) More Than 5 Minutes
Overdrive Off switch input too low for more than 5 minutes (4-speed auto. trans. only).
P0753
Trans 3-4 Shift Sol/Trans Relay Circuits
An open or shorted condition detected in the overdrive solenoid control circuit or Trans Relay Circuit in JTEC RE transmissions. Was MIL code 45.
P0753
An open or shorted condition detected in the transmission 2-4 shift solenoid circuit (4-speed auto. trans. only).
P0756
AW4 Shift Sol B (2-3) Functional Failure
Shift solenoid B (2-3) functional fault - Asin transmission
P0783
3-4 Shift Sol, No RPM Drop at Lockup
The overdrive solenoid is unable to engage the gear change from 3rd gear to the overdrive gear.
P0801
Reverse Gear Lockout circuit Open or Short
An open or shorted condition detected in the transmission reverse gear lock-out solenoid control circuit.
P0830
Clutch Depressed Switch Circuit
Problem detected in the clutch switch circuit.
P0833
Clutch Released Switch Circuit
P1110
Decrease Engine Performance Due To High Intake Air Temperature
Intake manifold air temperature is above the engine protection limit. Engine power will be derated.
P1180
P1195
1/1 O2 Sensor Slow During Catalyst Monitor
A slow switching oxygen sensor has been detected in bank 1/1 during catalyst monitor test. (Also see SCI DTC $66) (was P0133)
P1196 [br /]
2/1 O2 Sensor Slow During Catalyst Monitor
A slow switching oxygen sensor has been detected in bank 2/1 during catalyst monitor test. (Also see SCI DTC $7A) (was P0153)
P1197
1/2 O2 Sensor Slow During Catalyst Monitor
A slow switching oxygen sensor has been detected in bank 1/2 during catalyst monitor test. (Also see SCI DTC $68) (was P0139)
P1198
Radiator Temperature Sensor Volts Too High
Radiator coolant temperature sensor input above the maximum acceptable voltage.
P1199
Radiator Temperature Sensor Volts Too Low
Radiator coolant temperature sensor input below the minimum acceptable voltage.
P1281
Engine coolant temperature remains below normal operating temperatures during vehicle travel (Thermostat).
P1282
Fuel Pump Relay Control Circuit
An open or shorted condition detected in the fuel pump relay control circuit.
P1283
Idle Select Signal Invalid
ECM or fuel injection pump module internal fault condition detected.
P1284
Fuel Injection Pump Battery Voltage Out-Of-Range
Fuel injection pump module internal fault condition detected. Engine power will be derated.
P1285
Fuel Injection Pump Controller Always On
Fuel injection pump module relay circuit failure detected. Engine power will be derated.
P1286
Accelerator Position Sensor (APPS) Supply Voltage High
High voltage detected at APPS.
P1287
Fuel Injection Pump Controller Supply Voltage Low
ECM or fuel injection pump module internal fault condition detected. Engine power will be derated.
P1288
Intake Manifold Short Runner Solenoid Circuit
An open or shorted condition detected in the short runner tuning valve circuit.
P1289
Manifold Tune Valve Solenoid Circuit
An open or shorted condition detected in the manifold tuning valve solenoid control circuit.
P1290
CNG Fuel System Pressure Too High
Compressed natural gas system pressure above normal operating range.
P1291
No Temp Rise Seen From Intake Heaters
Energizing Heated Air Intake does not change intake air temperature sensor an acceptable amount.
P1291
No Temperature Rise Seen From Intake Air Heaters
Problem detected in intake manifold air heating system.
P1292
CNG Pressure Sensor Voltage Too High
Compressed natural gas pressure sensor reading above acceptable voltage.
P1293
CNG Pressure Sensor Voltage Too Low
Compressed natural gas pressure sensor reading below acceptable voltage.
P1294
Target Idle Not Reached
Target RPM not achieved during drive idle condition. Possible vacuum leak or IAC (AIS) lost steps.
P1295
No 5 Volts to TP Sensor
Loss of a 5 volt feed to the Throttle Position Sensor has been detected.
P1295
Accelerator Position Sensor (APPS) Supply Voltage Too Low
APPS supply voltage input below the minimum acceptable voltage.
P1296
No 5 Volts to MAP Sensor
Loss of a 5 volt feed to the MAP Sensor has been detected.
P1297
No Change in MAP From Start To Run
No difference is recognized between the MAP reading at engine idle and the stored barometric pressure reading.
P1298
Lean Operation at Wide Open Throttle
A prolonged lean condition is detected during Wide Open Throttle.
P1299
Vacuum Leak Found (IAC Fully Seated)
MAP Sensor signal does not correlate to Throttle Position Sensor signal. Possible Vacuum Leak.
P1388
Auto Shutdown Relay Control Circuit
An open or shorted condition detected in the ASD or CNG shutoff relay control ckt.
P1388
An open or shorted condition detected in the auto shutdown (ASD) relay circuit.
P1389
No ASD Relay Output Voltage At PCM
No Z1 or Z2 voltage sensed when the auto shutdown relay is energized.
P1389
An open condition detected in the ASD relay output circuit.
P1390
Timing Belt Skipped 1 Tooth or More
Relationship between Cam and Crank signals not correct.
P1391
Intermittent Loss of CMP or CKP
Loss of the Cam Position Sensor or Crank Position sensor has occurred. For PL 2.0L
P1398
Mis-Fire Adaptive Numerator at Limit
PCM is unable to learn the Crank Sensor's signal in preparation for Misfire Diagnostics. Probable defective Crank Sensor.
P1399
Wait To Start Lamp Circuit
An opn or shorted condition detected in the Wait to Start Lamp circuit.
P1403
No 5V to EGR Sensor
Loss of 5V feed to the EGR position sensor
P1475
Aux 5 Volt Supply Voltage High
Sensor supply voltage for ECM sensors is too high. (See also P01475)
P1475
Sensor supply voltage for ECM sensors is too high. (See also P1475)
P1476
Too Little Secondary Air
Insufficient flow of secondary air injection detected during aspirator test (was P0411)
P1477
Too Much Secondary Air
Excessive flow of secondary air injection detected during aspirator test (was P0411)
P1478
Battery Temp Sensor Volts Out of Limit
Internal temperature sensor input voltage out of an acceptable range.
P1479
Transmission Fan Relay Circuit
An open or shorted condition detected in the transmission fan relay circuit.
P1480
PCV Solenoid Circuit
An open or shorted condition detected in the PCV solenoid circuit.
P1481
EATX RPM Pulse Perf
EATX RPM pulse generator signal for misfire detection does not correlate with expected value.
P1482
Catalyst Temperature Sensor Circuit Shorted Low
Catalyst temperature sensor circuit shorted low.
P1483
Catalyst Temperature Sensor Circuit Shorted High
Catalyst temperature sensor circuit shorted high.
P1484
Catalytic Converter Overheat Detected
A catalyst overheat condition has been detected by the catalyst temperature sensor.
P1485
Air Injection Solenoid Circuit
An open or shorted condition detected in the air assist solenoid circuit.
P1486
Evap Leak Monitor Pinched Hose Found
LDP has detected a pinched hose in the evaporative hose system.
P1487
Hi Speed Rad Fan CtrL Relay Circuit
An open or shorted condition detected in the control circuit of the #2 high speed radiator fan control relay.
P1488
Auxiliary 5 Volt Supply Output Too Low
Auxiliary 5 volt sensor feed is sensed to be below an acceptable limit.
P1489
High Speed Fan CtrL Relay Circuit
An open or shorted condition detected in the control circuit of the high speed radiator fan control relay.
P1490
Low Speed Fan CtrL Relay Circuit
An open or shorted condition detected in the control circuit of the low speed radiator fan control relay.
P1491
Rad Fan Control Relay Circuit
An open or shorted condition detected in the radiator fan control relay control circuit. This includes PWM solid state relays.
P1492
Ambient/Batt Temp Sensor Volts Too High
External temperature sensor input above acceptable voltage.
P1492
Battery temperature sensor input voltage above an acceptable range.
P1493
Ambient/Batt Temp Sensor Volts Too Low
External temperature sensor input below acceptable voltage.
P1493
Battery temperature sensor input voltage below an acceptable range.
P1494
Leak Detection Pump Sw or Mechanical Fault
Incorrect input state detected for the Leak Detection Pump (LDP) pressure switch.
P1495
Leak Detection Pump Solenoid Circuit
An open or shorted condition detected in the Leak Detection Pump (LDP) solenoid circuit.
P1496
5 Volt Supply, Output Too Low
5 volt sensor feed is sensed to be below an acceptable limit. (less thean 4V for 4 seconds)
P1498
High Speed Rad Fan Ground CtrL Relay Circuit
An open or shorted condition detected in the control circuit of the #3 high speed radiator fan control relay.
P1499
Hydraulic cooling fan solenoid circuit
An open or shorted condition detected in the cooling fan control solenoid circuit.
P1594
Battery voltage sense input above target charging voltage during engine operation.
P1594
P1595
Speed Control Solenoid Circuits
An open or shorted condition detected in either of the speed control vacuum or vent solenoid control circuits.
P1595
An open or shorted condition detected in the speed control vacuum or vent solenoid control circuits.
P1596
Speed Control Switch Always High
Speed control switch input above maximum acceptable voltage.
P1597
Speed Control Switch Always Low
Speed control switch input below minimum acceptable voltage.
P1597
P1598
A/C Pressure Sensor Volts Too High
A/C pressure sensor input above maximum acceptable voltage.
P1598
A/C Sensor Input High
Problem detected in air conditioning electrical circuit.
P1599
A/C Pressure Sensor Volts Too Low
A/C pressure sensor input below minimum acceptable voltage.
P1599
A/C Sensor Input Low
P1680
Problem detected in clutch switch electrical circuit.
P1681
No I/P Cluster CCD/J1850 Messages Received
No CCD/J1850 messages received from the cluster control module.
P1682
Battery voltage sense input below target charging voltage during engine operation and no significant change in voltage detected during active test of generator output circuit.
P1682
Charging system output voltage low.
P1683
SPD CtrL PWR Relay; or S/C 12V Driver Circuit
An open or shorted condition detected in the speed control servo power control circuit.
P1683
P1684
Batt Loss in 50 Starts
The battery has been disconnected within the last 50 starts.
P1685
SKIM Invalid Key
The engine controller has received an invalid key from the SKIM.
P1686
No SKIM BUS Messages Received
No CCD/J1850 messages received from the Smart Key Immobilizer Module (SKIM)
P1687
No MIC BUS Message
No CCD/J1850 messages received from the Mechanical Instrument Cluster (MIC) module.
P1688
Internal Fuel Injection Pump Controller Failure
Internal problem within the fuel injection pump. Low power, engine derated, or engine stops.
P1689
No Communication Between ECM and Injection Pump Module
Data link circuit failure between ECM and fuel injection pump. Low power, engine derated, or engine stops.
P1690
Fuel Injection Pump CKP Sensor Does Not Agree With ECM CKP Sensor
Problem in fuel sync signal. Possible injection pump timing problem. Low power, engine derated, or engine stops.
P1691
Fuel Injection Pump Controller Calibration Error
Internal fuel injection pump failure. Low power, engine derated, or engine stops.
P1692
DTC Set In ECM
A "Companion DTC" was set in both the ECM and PCM.
P1693
DTC Detected In Companion Module
A fault has been generated in the companion engine control module.
P1693
DTC Detected In PCM/ECM or DTC Detected in ECM
P1694
Fault In Companion Module
No CCD/J1850 messages received from the powertrain control module-Aisin transmission.
P1694
No CCD Messages Received From ECM
Bus communication failure to PCM.
P1695
No CCD/J1850 Message From Body Control Module
No CCD/J1850 messages received from the body control module.
P1696
PCM Failure EEPROM Write Denied
Unsuccessful attempt to write to an EEPROM location by the control module.
P1697
PCM Failure SRI Mile Not Stored
Unsuccessful attempt to update Service Reminder Indicator (SRI or EMR) mileage in the control module EEPROM.
P1698
No CCD/J1850 Message From TCM
No CCD/J1850 messages received from the electronic transmission control module (EATX) or the Aisin transmission controller.
P1698
No CCD Messages Received From PCM
Bus communication failure to PCM. A "Companion DTC" was set in both the ECM and PCM.
P1719
Skip Shift Solenoid Circuit
AN open or shorted condition detected in the transmission 2-3 gear lock-out solenoid control circuit.
P1740
TCC or OD Sol Perf
A rationality error has been detected in either the TCC solenoid or overdrive solenoid systems.
P1740
TCC OR O/D Solenoid Performance
Problem detected in transmission convertor clutch and/or overdrive circuits (diesel engine with 4-speed auto. trans. only).
P1756
GOV Press Not Equal to Target @ 15-20 PSI
The requested pressure and the actual pressure are not within a tolerance band for the Governor Control System which is used to regulate governor pressure to control shifts for 1st, 2nd, and 3rd gear. (Mid Pressure Malfunction)
P1756
Governor sensor input not between 10 and 25 psi when requested (4-speed auto trans only).
P1757
The requested pressure and the actual pressure are not within a tolerance band for the Governor Control System which is used to regulate governor pressure to control shifts for 1st, 2nd, and 3rd gear. (Zero Pressure Malfunction)
P1757
Governor Pressure Above 3 PSI in Gear With 0 MPH
Governor pressure greater than 3 psi when requested to be 0 psi (4-speed auto trans only).
P1762
Gov Press Sen Offset Volts Too Lo or High
The Governor Pressure Sensor input is greater than a calibration limit or is less than a calibration limit for 3 consecutive park/neutral calibrations.
P1762
Governor Press Sen Offset Volts Too Low or High
Sensor input greater or less than calibration for 3 consecutive Neutral/Park occurrences (4-speed auto trans only).
P1763
Governor Pressure Sensor Volts Too Hi
The Governor Pressure Sensor input is above an aceeptable voltage level.
P1763
Voltage greater than 4.89 volts (4-speed auto trans only).
P1764
Governor Pressure Sensor Volts Too Low
The Governor Pressure Sensor input is below an acceptable voltage level.
P1764
Voltage less than .10 volts (4-speed auto trans only).
P1765
Trans 12 Volt Supply Relay CtrL Circuit
An open or shorted condition is detected in the Transmission Relay control circuit. This relay supplies power to the TCC.
P1765
Current state of solenoid output port is different than expected (4-speed auto trans only).
P1899
P/N Switch Stuck in Park or in Gear
Incorrect input state detected for the Park/Neutral switch.
P1899
Incorrect input state detected for the Park/Neutral switch (3 or 4-speed auto trans only).
Hey @Chris,
Thanks for this. Are these the same codes that would appear on the dash display if I flip the power on and off three times quickly? I ask because when I do that, I see a few two digit codes like 12 and 55, but those aren’t on your list.
Hey @Chris,
No, these aren’t the same but I believe there is a thread for those codes in the resources section though.
Reactions: SSTJ
Hey @Chris,
On the 1997, the codes are different. 55 means report is complete, 12 means the battery was disconnected or power momentarily lost. Full list here and I think in the FSM.
https://www.offroaders.com/tech/jeep/TJ_diagnostic_codes.htm
Reactions: SSTJ
Only 1997 and 2001-2006 can do the key trick. 1997s show the 2 digit OBD-I codes and the rest show 4 digit OBD-II P codes in the odometer display. If you use a code reader, all model years show 4 digit OBD-II P codes.
Reactions: SSTJ
