Battery - Charging System (1997 - 2006)
Body (1997 - 2006)
Brakes (1997 - 2006)
Brakes - Antilock (1997 - 2006)
Clutch (1997 - 2006)
If you choose to replace your Wrangler's clutch yourself you will need these specs along witd tdose of the transfer case, transmission, and belly pan.
Cooling System (1997 - 2006)
Differential and Driveline - Propeller Shafts & U-Joints (1997-2006)
Differential and Driveline - Front Axle (1997)
Differential and Driveline - 181 FBI Axle (1998 - 2006)
Also called the Dana 30, the 181FBI is a front beam type axle. All TJ Wranglers other than Rubicon models came standard witd a Dana 30 front axle.
Differential and Driveline - 216 RBI Rear Axle (1997)
These torque specs come in handy if you are changing differential fluid, rebuilding the axle, or regearing. these specs only apply for the front Dana 44 axle for TJ Wranglers. Dana 44 front axles came standard on Rubicon models, it was not available for any other models.
Differential and Driveline - 216 RBI Rear Axle (1998-2006)
Differential and Driveline - 194 RBI Rear Axle (1997)
The 194 RBI is also called the Dana 35 and came standard in all TJ Wranglers other tdan the Rubicon.
Note: Refer to pinion gear removal and installation procedures for proper pinion nut tightening instructions. Do not exceed 427 N-m (315 ft. lbs.) during collapsible spacer crushing procedure.
Differential and Driveline - 194 RBI Axle (1998-2006)
Emissions Control (1997-2006)
The evaporative emissions (Evap) system is used to prevent hydro-carbons from escaping into the atmosphere.
Engine - 2.5L (1997-2002)
The oxygen sensors require a special socket to be removed due to the wires. Also be sure to note that there are different specs for each set of bolts.
Engine - 4.0L (1997-2006)
This engine is one of the most popular engines that Jeep has ever put into their vehicles. The torque specs needed to rebuild the inline six if the need should arise.
Engine - 2.4L (2003-2006)
This engine was used from 2003 to 2006 and served as the successor to the 2.5 liter engine.
Exhaust & Intake Manifolds (1997-2006)
The oxygen sensors require a special socket to be removed due to the wires. Also be sure to note that these are different specs for each set of bolts.
Frame and Bumpers (1997-2006)
There will be six bolts for the front bumper. Four on top and two underneath. On the rear bumper, there are two nuts that need to be removed from each side and two bolts going into the bottom side of the frame.
Fuel System (1997-2006)
Use caution when servicing any part of the fuel system. Wear safety glasses to prevent eye exposure. If gasoline gets into your eyes immediately flush them with water for 15 minutes. If irritation persists call a doctor.
Ignition System (1997-2006)
Steering (1997-2006)
Steering Linkage (1997-2006)
If you do any work on your steering or suspension it is a good policy to re-torque your steering components. With something like your steering linkage, you want to be sure everything is tight or else you could experience some vibrations.
Power Steering (1997-2006)
The power steering system in TJ wranglers changed after in 2003. Wranglers from 1997-2002 use power steering fluid, 2003-2006 use ATF 4. These fluids should not be mixed, be sure to check your owners manual for all recommended fluid types.
Steering - Manual Steering (1997-2006)
The specs for manual and power are different so be sure to use the correct specs.
Suspension - Front (1997-2006)
Suspension - Rear (1997-2006)
NOTE: Refer to Pinion Gear Removal and installation procedures for proper pinion nut tightening instructions. Do not exceed 352 N-m (260 ft. lbs.) during collapsible spacer crushing procedure.
Transmission & Transfer Case - AX15 Manual (1997 - 1999)
Transmission & Transfer Case - NV1500 Manual (2003-2004)
Transmission & Transfer Case - NV3550 Manual (2000 - 2004)
Transmission & Transfer Case - NSG370 Manual (2005 - 2006)
Transmission & Transfer Case - 30/32RH Automatic (1997-2002)
Transmission & Transfer Case - 42RLE Automatic (2003-2006)
Transmission & Transfer Case - NV231 Transfer Case (1997-2006)
The NV231 is also commonly referred to as Command-Trac. It is a shift-on-the-fly part time 4WD transfer case. This transfer case has a 2.72-1 gear ratio in 4-Low.
Transmission & Transfer Case - NV241 Transfer Case (2003 - 2006)
The NV241 is a shift-on-the-fly part time 4WD transfer case. This transfer case has a 4-1 gear ratio in 4-Low.
Tires and Wheels (1997 - 2006)
Component | Torque |
Generator Upper Mounting Bolt 2.5/4.0L Engine | 55 N-m (41 ft. lbs.) |
Generator Lower Mounting Bolt 2.5L/4.0L Engine | 55 N-m (41 ft. lbs.) |
Battery Terminal Nut | 8.5 N-m (75 in. lbs.) |
Ground Terminal Nut | 8.5 N-m (75 in. lbs.) |
Harness Hold-down Nut | 8.5 N-m (75 in. lbs.) |
Field Terminal Nuts | 2.8 N-m (25 in. lbs.) |
Body (1997 - 2006)
Hood hinge screws | 17 N-m (155 in. lbs.) |
Bucket seat front anchor bolt | 47 N-m (35 ft. lbs.) |
Bucket seat rear inboard anchor bolt | 74 N-m (55 ft. lbs.) |
Bucket seat rear outboard anchor bolt | 33 N-m (25 ft. lbs.) |
Liftgate glass ball stud nut | 12 N-m (112 in. lbs.) |
Liftgate glass hinge nut | 6 N-m (53 in. lbs.) |
Liftgate hinge to hardtop bolt | 10 N-m (95 in. lbs.) |
Front turning loop bolt | 47 N-m (35 ft. lbs.) |
Front retractor bolt | 47 N-m (35 ft. lbs.) |
Rear retractor bolt | 47 N-m (35 ft. lbs.) |
Rear turning loop bolt | 47 N-m (35 ft. lbs.) |
Rear belt anchor bolt | 47 N-m (35 ft. lbs.) |
Rearview mirror setscrew | 1 N-m (9 in. lbs.) |
Rear buckle anchor bolt | 43 N-m (32 ft. lbs.) |
Side support bar to sport bar bolts | 71 N-m (53 ft. lbs.) |
Sport bar to wheelhouse bolts | 40 N-m (30 ft. lbs.) |
Sport bar to cargo floor bolts | 40 N-m (30 ft. lbs.) |
Sport bar to windshield frame bolts | 32 N-m (24 ft. lbs.) |
Tailgate hinge screws | 23 N-m (200 in. lbs.) |
Tailgate striker | 71 N-m (52 ft. lbs.) |
Brake pedal support bolt | 28 N-m (21 ft. lbs.) |
Brake boost mounting nuts | 37 N-m (27 ft. lbs.) |
Master cylinder mounting nuts | 24 N-m (18 ft. lbs.) |
Master cylinder brake lines | 15 N-m (11 ft. lbs.) |
Combination valve mounting nuts | 24 N-m (18 ft. lbs.) |
Combination valve brake lines | 21 N-m (15 ft. lbs.) |
Caliper mounting bolts | 15 N-m (11 ft. lbs.) |
Caliper brake hose bolt | 31 N-m (23 ft. lbs.) |
Wheel cylinder mounting bolts | 10 N-m (7 ft. lbs.) |
Wheel cylinder brake line | 16 N-m (12 ft. lbs.) |
Parking brake lever bolts | 12 N-m (9 ft. lbs.) |
Parking brake lever bracket bolts | 12 N-m (9 ft. lbs.) |
Cable retainer nut | 1.5 N-m (14 in. lb.s) |
Acceleration Sensor Bolt | 8-9 N-m (71-83 in. lbs.) |
G-Sensor Bolt (2004) | 4-5 N-m (35-45 in. lbs.) |
Acceleration Sensor Bracket Bolt | 1-2 N-m (13-18 in. lbs.) |
Hydraulic Control Unit Mounting Bolts | 20 N-m (177 in. lbs.) |
Hydraulic Control Unit Bracket Mounting Bolts | 4-9 N-m (35-76 in. lbs.) |
Hydraulic Control Unit Body Bracket Bolts (2004) | 16-24 N-m (142-212 in. lbs.) |
Hydraulic Control Unit Brake Lines | 16 N-m (144 in. lbs.) |
Controller Antilock Brakes Mounting Bolts | 8-13 N-m (75-115 in. lbs.) |
Wheel Speed Sensor Front Mounting Bolt | 4-6 N-m (34-50 in. lbs.) |
Wheel Speed Sensor Rear Mounting Bolt | 12-14 N-m (106-124 in. lbs.) |
Bolts, clutch cover 2.5L and 2.4L | 31 N-m (23 ft. lbs.) |
Bolts, clutch cover 4.0L | 52 N-m (38 ft. lbs.) |
Nut, clutch master cylinder | 38 N-m (28 ft. lbs.) |
Nut, clutch slave cylinder | 23 N-m (17 ft. lbs.) |
Bolt, clutch housing M12 | 75 N-m (55 ft. lbs.) |
Bolt, clutch housing 3/8 | 37 N-m (27 ft. lbs.) |
Bolt, clutch housing 7/16 | 58 N-m (43 ft. lbs.) |
Bolt, clutch housing/trans | 38 N-m (28 ft. lbs.) |
Bolt, dust shield lower | 50 N-m (37 ft. lbs.) |
Bolt, X-Member/frame | 41 N-m (30 ft. lbs.) |
Bolt, X-Member/rear support | 45 N-m (33 ft. lbs.) |
Bolts, flywheel 4.0L | 142 N-m (105 ft. lbs.) |
Bolts, flywheel 2.5L and 2.4L | 68 N-m (50 ft. lbs. 1/4 turn) |
Bolts, U-joints | 19 N-m (170 in. lbs.) |
Generator Pivot Bolt | 38 N-m (28 ft. lbs.) |
Generator Rear Adjusting Bolt | 27 N-m (20 ft. lbs.) |
Auto Trans Auxillary Oil Cooler Mounting Bolts | 2 N-m (18 in. lbs.) |
Fan Blade-to-Viscous Fan Drive Bolts | 24 N-m (18 ft. lbs.) |
3.7L Fan Blade Assembly to Viscous Drive Bolts (2004) | 23 N-m (210 in. lbs.) |
Viscous Fan Drive-to-Water Pump Nuts | 27 N-m (20 ft. lbs.) |
Fan Shroud Screws (2.5L) | 16 N-m (12 ft. lbs.) |
Fan Shroud Screws (4.0L) | 4 N-m (31 in. lbs.) |
Electric Fan to Fan Shroud Bolt (2004) | 5 N-m (50 in. lbs.) |
Engine Block Heater Fastener | 4 N-m (31 in. lbs.) |
Engine Block Heater Bolt (2004 2.4L) | 2 N-m (17 in. lbs.) |
Thermostat Housing Bolts | 20 N-m (15 ft. lbs.) |
Water Pump Bolts (2.5L and 4.0L) | 30 N-m (22 ft. lbs.) |
Water Pump Bolts (2004 4.0L) | 23 N-m (200 in. lbs.) |
Water Pump Bolts (2004 2.4L) | 12 N-m (105 in. lbs.) |
Automatic Belt Tensioner to Mounting Bracket (2004 2.4L) | 41 N-m (30 ft. lbs.) |
Automatic Belt Tensioner Pulley Bolt (2004 2.4L) | 61 N-m (45 ft. lbs.) |
Coolant Overflow Bottle to Plenum Bolts (2004 2.4L) | 8.5 N-m (75 in. lbs.) |
Fan Shroud to Radiator Mounting Bolts (2004) | 8 N-m (70 in. lbs.) |
Radiator Upper Isolator to Crossmember Bolts (2004) | 9.5 N-m (85 in. lbs.) |
Thermostat Housing Bolts (2004 2.4L) | 28 N-m (250 in. lbs.) |
Front Shaft Transfer Case Yoke Bolts | 27 N-m (20 ft. lbs.) |
Front Yoke Bolts (1998) | 41 N-m (30 ft. lbs.) |
Axle Yoke Bolts (front and rear) | 19 N-m (14 ft. lbs.) |
Fill Hole Plug | 34 N-m (25 ft. lbs.) |
Differential Cover Bolt | 41 N-m (30 ft. lbs.) |
Bearing Cap Bolt | 61 N-m (45 ft. lbs.) |
Ring Gear Bolt | 95-122 N-m (70-90 ft. lbs.) |
Axle Nut | 237 N-m (175 ft. lbs.) |
Wheel Bearing Bolt | 102 N-m (75 ft. lbs.) |
Lower Ball Joint Stud | 108 N-m (80 ft. lbs.) |
Upper Ball Joint Stud | 101 N-m (75 ft. lbs.) |
ABS Sensor Bolt | 11 N-m (96 in. lbs.) |
Pinion Nut (Minimum) | 17 N-m (160 in. lbs.) |
Diff. Cover Bolt | 41 N-m (30 ft. lbs.) |
Hub Bearing Bolt | 102 N-m (75 ft. lbs.) |
Fill plug | 34 N-m (25 ft. lbs.) |
Diff. cover bolts | 41 N-m (30 ft. lbs.) |
Diff. Bearing Cap bolts | 108 N-m (80 ft. lbs.) |
Ring gearbolts | 108 N-m (80 ft. lbs.) |
Brake backing plate nuts | 61 N-m (45 ft. lbs.) |
Pinion gear nut (minimum) | 244 N-m (180 ft. lbs.) |
Diff. bearing cap bolts | 108 N-m (80 ft. lbs.) |
Ring gear bolts | 108 N-m (80 ft. lbs.) |
Pinion gear nut (minimum) | 217 N-m (160 ft. lbs.) |
Pinion gear nut (minimum) | 292 N-m (215 ft. lbs.) |
Bearing cap bolts | 77 N-m (57 ft. lbs.) |
Pinion nut | 271-474 N-m (200-350 ft. lbs.) |
Pinion mate shaft lock screw | 16.25 N-m (12 ft. lbs.) |
Ring gearbolt | 95-122 N-m (70-90 ft. lbs.) |
ABS sensor bolt | 8 N-m (70 in. lbs.) |
EVAP canister mounting bolt | 9 N-m (80 in. lbs.) |
Leak detection pump (LDP) filter mounting bolts (1998) | 7 N-m (65 in. lbs.) |
LDP mounting screws (1998) | 1 N-m (11 in. lbs.) |
EVAP canister/LDP mounting bracket-to-body nuts (2004) | 250 in. lbs. |
EVAP canister/LDP mounting bracket-to-body bolts (2004) | 212 in. lbs. |
A/C compressor bracket-to-engine bolts | 34 N-m (25 ft. lbs.) |
A/C compressor mounting bolts | 27 N-m (20 ft. lbs.) |
A/C low pressure service valve nut | 38 N-m (28 ft. lbs.) |
Block heater nut | 1.8 N-m (16 in. lbs.) |
Camshaft sprocket bolt | 108 N-m (80 ft. lbs.) |
Connecting rod nuts | 45 Npm (33 ft. lbs.) |
Converter plate bolts | 68 N-m (50 ft. lbs.) at 60 degrees |
Cylinder block drain plugs | 41 N-m (30 ft. lbs.) |
Cylinder head bolts 1-10 & 12-14 | 149 N-m (110 ft. lbs.) |
Cylinder head bolt 11 | 135 N-m (100 ft. lbs.) |
Cylinder head cover bolts | 10 N-m (85 in. lbs.) |
Drive plate-to-torque converter bolts | 54 N-m (40 ft. lbs.) |
Engine shock damper stud nuts | 23 N-m (17 ft. lbs.) |
Engine Mounts - Front | |
Cushion to black bracket nuts | 69 N-m (51 ft. lbs.) |
Cushion to frame bolts | 61 N-m (45 ft. lbs.) |
Bracket to engine block screw | 61 N-m (45 ft. lbs.) |
Bracket to engine block nut | 61 N-m (45 ft. lbs.) |
Bracket to engine block stud | 61 N-m (45 ft. lbs.) |
Engine Mounts - Rear | |
Trans cushion to crossmember nut | 28 N-m (21 ft. lbs.) |
Trans bracket to skid plate nut | 28 N-m (21 ft. lbs.) |
Trans mount to trans bracket nut | 41 N-m (30 ft. lbs.) |
Trans bracket to trans | 54 N-m (40 ft. lbs.) |
Exhaust manifold/pipe nuts | 27 N-m (20 ft. lbs.) |
Flywheel/converter housing bolts | 38 N-m (28 ft. lbs.) |
Flywheel/crankshaft bolts | 143 N-m (105 ft. lbs.) |
Front cover-to-block bolts 1/4-20 | 7 N-m (60 in. lbs.) |
Front cover-to-block bolts 5/16-18 | 22 N-m (192 in. lbs.) |
Fuel pump bolts | 22 N-m (16 ft. lbs.) |
Generator adjusting bolt | 24 N-m (18 ft. lbs.) |
Generator pivot bolt/nut | 38 N-m (28 ft. lbs.) |
Generator mounting bracket-to-engine bolts | 38 N-m (28 ft. lbs.) |
Generator mounting/head bolts | 45 N-m (33 ft. lbs.) |
Main bearing bolts | 108 N-m (80 ft. lbs.) |
Oil filter | 18 N-m (13 ft. lbs.) |
Oil filter connector | 54 N-m (40 ft. lbs.) |
Oil gallery plug | 41 N-m (30 ft. lbs.) |
Oil pan1/4-20 bolts | 9.5 N-m (84 in. lbs.) |
Oil pan5/16-18 bolts | 15 N-m (132 in. lbs.) |
Oil pandrain plug | 34 N-m (25 ft. lbs.) |
Oil pump short attaching bolts | 23 N-m (17 ft. lbs.) |
Oil pump long attaching bolts | 23 N-m (17 ft. lbs.) |
Oil pump cover bolts | 8 N-m (70 in. lbs.) |
Power steering pump pressure hose nut | 52 N-m (38 ft. lbs.) |
Rocker arm assembly-to-cylinder head capscrews | 28 N-m (21 ft. lbs.) |
Spark plugs | 37 N-m (27 ft. lbs.) |
Starter motor mountingbolts | 45 N-m (33 ft. lbs.) |
Thermostat housing bolts | 18 N-m (13 ft. lbs.) |
Vibration damper bolts | 108 N-m (80 ft. lbs.) |
Water pump/block bolts | 31 N-m (270 in. lbs.) |
Connecting rod nuts | 45 N-m (33 ft. lbs.) |
Cylinder head cover bolts | 10 N-m (85 in. lbs. |
Support bracket bolts | 61 N-m (45 ft. lbs.) |
Support cushion bolts/nuts | 41 N-m (30 ft. lbs.) |
Support cushion bracket bolts | 54 N-m (40 ft. lbs.) |
Support cushion bracket stud nuts | 41 N-m (30 ft. lbs.) |
Support cushion tdru-bolt | 65 N-m (48 ft. lbs.) |
Crossmember to sill bolts (automatics) | 41 N-m (30 ft. lbs.) |
Insulator stud assembly nut | 41 N-m (30 ft. lbs.) |
Support cushion crossmember nuts | 22 N-m (192 in. lbs.) |
Support cushion/bracket nuts (manuals) | 75 N-m (55 ft. lbs.) |
Transmission support bracket bolt (manuals) | 46 N-m (34 ft. lbs.) |
Transmission support bracket/cushion bolt (4WD auto) | 75 N-m (55 ft. lbs.) |
Transmission support adaptor bracket bolts (2WD auto) | 75 N-m (55 ft. lbs.) |
Front cover-to-block 5/16-18 | 22 N-m (16 ft. lbs.) |
Oil galley plug | 41 N-m (30 ft. lbs.) |
Oil pump attaching bolts | 23 N-m (17 ft. lbs.) |
Starting motor mounting bolts | 45 N-m (33 ft. lbs.) |
Balance shaft carrier to block bolts | 54 N-m (40 ft. lbs.) |
Balance shaft gear cover double ended fastener | 12 N-m (105 in. lbs.) |
Balance shaft sprocket bolt | 28 N-m (250 in. lbs.) |
Balance shaft chain tensioner bolts | 12 N-m (105 in. lbs.) |
Balance shaft carrier cover bolts | 12 N-m (105 in. lbs.) |
Camshaft sprocket bolt | 101 N-m (75 ft. lbs.) |
Connecting rod cap bolts | 54 1/4 turn N-m (40 1/4 turn ft. lbs.) |
Crankshaft main bearing cap/bedplate M8 bolts | 34 N-m (250 in. lbs.) |
Crankshaft main bearing cap/bedplate M11 bolts | 41 1/4 turn N-m (30 1/4 turn ft. lbs.) |
Crankshaft damper | 136 N-m (100 ft. lbs.) |
Flex plate to crankshaft | 95 N-m (70 ft. lbs.) |
Flywheel mounting bolts | 81 N-m (60 ft. lbs.) |
Right engine mount bracket bolts | 61 N-m (45 ft. lbs.) |
Exhaust manifold to cylinder head bolts | 23 N-m (200 in. lbs.) |
Exhaust manifold heat shield bolts | 12 N-m (105 in. lbs.) |
Lower intake manifold bolts | 28 N-m (250 in. lbs.) |
Oil filter | 20 N-m (15 ft. lbs.) |
Oil panbolts | 12 N-m (150 in. lbs.) |
Oil pandrain plug | 27 N-m (20 ft. lbs.) |
Oil pump cover plate bolts | 12 n-m (105 in. lbs.) |
Oil pump pickup tube bolts | 28 N-m (20 ft. lbs.) |
Oil pump relief valve cap | 41 N-m (30 ft. lbs.) |
Spark plugs | 28 N-m (250 in. lbs.) |
Timing belt front cover to rear cover bolts | 12 N-m (105 in. lbs.) |
Timing belt rear cover bolts | 12 N-m (105 in. lbs.) |
Timing belt tensioner assembly bolts | 61 N-m (45 ft. lbs.) |
Crossmember to sill bolts | 41 N-m (30 ft. lbs.) |
Exhaust pipe to manifold nuts | 31 N-m (23 ft. lbs.) |
Exhaust manifold 2.5L engine bolts #2-5 | 31 N-m (23 ft. lbs.) |
Exhaustmanifold 2.5L engine nuts #6-7 | 31 N-m (23 ft. lbs.) |
Exhaust manifold 4.0L engine nuts/bolts #1-5 & #8-11 | 33 N-m (24 ft. lbs.) |
Exhaust manifold 4.0lL engine nuts #6-7 | 31 N-m (23 ft. lbs.) |
Intake manifold 2.5L engine bolt #1 | 41 N-m (30 ft. lbs.) |
Intake manifold 2.5L engine bolts #2-5 | 31 N-m (23 ft. lbs.) |
Muffler to catalytic converter clamp nut | 48 N-m (35 ft. lbs.) |
Oxygen sensors | 48 N-m (35 ft. lbs.) |
Components | Torque |
Front bumper screw | 104 N-m (77 ft. lbs.) |
Front bumper scew (2004) | 108 N-m (80 ft. lbs.) |
Front tow hook screw | 108 N-m (80 ft. lbs.) |
Front tow eye screw | 108 N-m (80 ft. lbs.) |
Fuel tank skid plate nuts | 16 N-m (138 in. lbs.) |
Fuel tank strap nuts | 5 N-m (40 in. lbs.) |
Radiator to frame hold down bolt (2004) | 60 N-m (45 ft. lbs.) |
Rear bumper bolt | 67 N-m (50 ft. lbs.) |
Rear bumper bolt (2004) | 77 N-m (57 ft. lbs.) |
Rear bumper nut | 67 N-m (50 ft. lbs.) |
Rear tow eye screw | 47 n-m (35 ft. lbs.) |
Rear tow hook screw (2004) | 77 N-m (57 ft. lbs.) |
Transfer case skid plate bolts | 74 N-m (55 ft. lbs.) |
Transmission mount nuts | 28 N-m (21 ft. lbs.) |
Transmission mount nuts (2004) | 35 N-m (26 ft. lbs.) |
Transmission skid plate to frame bolts (2004) | 45 N-m (33 ft. lbs.) |
Transmission skid plate to transfer case skid plate (2004) | 28 N-m (21 ft. lbs.) |
Accelerator pedal bracket mounting nuts | 8.5 N-m (75 in. lbs.) |
Fuel pump module locknut | 34 N-m (25 ft. lbs.) |
Fuel pump module locknut (1998) | 62 N-m (45 ft. lbs.) |
Fuel rail mounting bolts or nuts | 11 N-m (100 in. lbs.) |
Fuel tank skidplate bolts | 16 N-m (141 in. lbs.) |
Fuel tank mounting strap bolts | 5 N-m (40 in. lbs.) |
Engine coolant temperature sensor | 11 N-m (96 in. lbs.) |
Fuel hoseclamps | 1 N-m (10 in. lbs.) |
Fuel hoseclamps (1998) | 3 N-m (25 in. lbs.) |
IAC motor-to-tdrottle body bolts | 7 N-m (60 in. lbs.) |
Intake manifold air temp sensor | 28 N-m (20 ft. lbs.) |
MAP sensor mounting screws | 3 N-m (25 in. lbs.) |
Oxygen sensor | 30 N-m (22 ft. lbs.) |
PCM mounting screws | 4 N-m (35 in. lbs.) |
Power steering pressure switch | 28 N-m (252 in. lbs.) |
tdrottle body mounting bolts | 12 N-m (108 in. lbs.) |
tdrottle position sensor mounting screws | 7 N-m (60 in. lbs.) |
Vehicle speed sensor mounting bolt | 2.2 N-m (20 in. lbs.) |
Crankshaft position sensor bolts witd manual transmission | 19 N-m (14 ft. lbs.) |
Crankshaft position sensor nuts - 2.5L w/ auto trans | 19 N-m (14 ft. lbs.) |
Crankshaft position sensor bolt - 4.0L w/ auto trans | 7 N-m (60 in. lbs.) |
Distributor hold down bolt | 23 N-m (17 ft. lbs.) |
Distributor cap screws | 3 N-m (26 in. lbs.) |
Ignition coil mounting (if tapped bolts are used) | 5 N-m (50 in. lbs.) |
Ignition coil mounting (if nuts/bolts are used) | 11 N-m (100 in. lbs.) |
Spark plugs (all engines) | 41 N-m (30 ft. lbs.) |
Power steering pump bracket to pump | 28 N-m (21 ft. lbs.) |
Power steering pump bracket to engine | 47 N-m (35 ft. lbs.) |
Power steering pump flow control valve | 75 N-m (55 ft. lbs.) |
Power steering pump pressure line | 28 N-m (21 ft. lbs.) |
Tilt steering column steering wheel nut | 54 N-m (40 ft. lbs.) |
Tilt steering column mounting nuts | 23 N-m (17 ft. lbs.) |
Tilt steering column coupler bolt | 49 N-m (36 ft. lbs.) |
Non-tilt steering column steering wheel nut | 54 N-m (40 ft. lbs.) |
Non-tilt steering column mounting nuts | 23 N-m (17 ft. lbs.) |
Non-tilt steering column coupler bolt | 49 N-m (36 ft. lbs.) |
Non-tilt steering column upper bracket nut | 17 N-m (150 in. lbs. |
Pitman arm shaft | 251 N-m (185 ft. lbs.) |
Drag link ball studs | 74 N-m (55 ft. lbs.) |
Drag link clamp | 49 N-m (36 ft. lbs.) |
Tie rod ends - ball studs | 74 N-m (55 ft. lbs.) |
Tie rod ends - clamp | 27 N-m (20 ft. lbs.) |
Tie rod puller ball stud | 88 N-m (65 ft. lbs.) |
Steering damper - frame | 74 N-m (55 ft. lbs.) |
Steering damper - drag link | 74 n-m (55 ft. lbs.) |
Adjustment cap locknut | 108 N-m (80 ft. lbs.) |
Adjustment screw locknut | 49 N-m (36 ft. lbs.) |
Gear to frame bolts | 95 N-m (70 ft. lbs.) |
Pitman shaft nut | 251 N-m (185 ft. lbs.) |
Rack piston plug | 102 N-m (75 ft. lbs.) |
Side cover bolts | 60 N-m (44 ft. lbs.) |
Pressure line | 28 N-m (21 ft. lbs.) |
Return line | 28 N-m (21 ft. lbs.) |
Adjustment Cap Locknut | 68 N-m (50 ft. lbs.) |
Adjustment Screw Locknut | 34 N-m (25 ft. lbs.) |
Pitman Shaft Nut | 251 N-m (185 ft. lbs.) |
Guide Clamp Screws | 14 N-m (10 ft. lbs.) |
Cover Bolts | 61 N-m (45 ft. lbs.) |
Gear to Frame Bolts | 105 N-m (78 ft. lbs.) |
Upper Shock Absorber Nut | 23 N-m (17 ft. lbs.) |
Lower Shock Absorber Nut | 28 N-m (250 in. lbs.) |
Suspension Arm Lower | |
Axle Bracket Nut | 115 N-m (85 ft. lbs.) |
Axle Bracket Nut (2003) | 163 N-m (120 ft. lbs.) |
Axle Bracket Nut (2004) | 176 N-m (130 ft. lbs.) |
Frame Bracket Nut | 176 N-m (130 ft. lbs.) |
Suspension Arm Upper | |
Axle Bracket Nut | 75 N-m (55 ft. lbs.) |
Axle Bracket Nut (2004) | 81 N-m (60 ft. lbs.) |
Frame Bracket Bolt | 75 N-m (55 ft. lbs.) |
Frame Bracket Bolt (2004) | 81 N-m (60 ft. lbs.) |
Stabilizer Bar | |
Retainer Bolts | 54 N-m (40 ft. lbs.) |
Retainer Bolts (2004) | 61 N-m (45 ft. lbs.) |
Link Upper Nut | 61 N-m (45 ft. lbs.) |
Link Lower Bolt | 95 N-m (70 ft. lbs.) |
Link Lower Bolt (2004) | 102 N-m (75 ft. lbs.) |
Track Bar | |
Ball Stud Nut | 88 N-m (65 ft. lbs.) |
Ball Stud Nut (2004) | 81 N-m (60 ft. lbs.) |
Axle Bracket Bolt | 75 N-m (55 ft. lbs.) |
Axle Bracket Bolt (2004) | 54 N-m (40 ft. lbs.) |
Hub/Bearing (1998) | |
Bolts | 102 N-m (75 ft. lbs.) |
Upper Shock Absorber Bolts | 31 N-m (23 ft. lbs.) |
Lower Shock Absorber Nut | 100 N-m (74 ft. lbs.) |
Axle Bracket Nut | 177 N-m (130 ft. lbs.) |
Frame Bracket Nut | 177 N-m (130 ft. lbs.) |
Stabilizer Bar | 75 N-m (55 ft. lbs.) |
Link Nut/Bolt | 54 N-m (40 ft. lbs.) |
Track Bar | |
Frame Bracket Nut | 100 N-m (74 ft. lbs.) |
Axle Bracket Bolt | 100 N-m (74 ft. lbs.) |
Access plugs | 19 N-m (14 ft. lbs.) |
Adapter Housing Bolts | 34 N-m (25 ft. lbs.) |
Back-up Light Switch | 44 N-m (32.5 ft. lbs.) |
Drain and Fill Plugs | 44 N-m (32.5 ft. lbs.) |
Front Bearing Retainer Bolts | 17 N-m (12 ft. lbs.) |
Interlock and Detent Plugs | 19 N-m (14 ft. lbs.) |
Propeller Shaft Clamp Screws | 16-23 N-m (140-200 in. lbs.) |
Rear Mount toTransmission Bolts | 33-60 N-m (24-44 ft. lbs.) |
Rear Mount Clevis Nut | 54-75 N-m (40-55 ft. lbs.) |
Rear Mount toCrossmember Nuts | 33-49 N-m (24-36 ft. lbs.) |
Restrictor Pins | 27.4 N-m (20 ft. lbs.) |
Reverse Shift Arm Bracket Bolts | 18 N-m (13 ft. lbs.) |
Shift Arm Set Screws | 38 N-m (28 ft. lbs.) |
Shift Fork Set Screws | 20 N-m (15 ft. lbs.) |
Shift Knob Nut | 20-34 N-m (15-25 ft. lbs.) |
Shifter Floor Cover Screws | 2-3 N-m (17-30 in. lbs.) |
Shift Tower Bolts | 18 N-m (13 ft. lbs.) |
Transfer Case Mounting Nuts | 30-41 N-m (22-30 ft. lbs.) |
Access Plugs | 19 N-m (14 ft. lbs.) |
Interlock andDetent Plugs | 19 N-m (14 ft. lbs.) |
Rear Mount to Transmission Bolts | 33-60 N-m (24-44 ft. lbs.) |
Rear Mount to Crossmember Nuts | 33-49 N-m (24-36 ft. lbs.) |
Shift Arm Set Screw | 38 N-m (28 ft. lbs.) |
Shift Knob Nut | 2-3 N-m (17-30 in. lbs.) |
Back Up Lamp Switch | 41 N-m (30 ft. lbs.) |
Countershaft Bearing Shim Cap | 41 N-m (30 ft. lbs.) |
Bearing Retainer - Front | 41 N-m (30 ft. lbs.) |
Bearing Retainer - Rear | 34 N-m (25 ft. lbs.) |
Drain/Fill Plug | 34 N-m (25 ft. lbs.) |
Shift Shaft Lock Bolt | 27 N-m (20 ft. lbs.) |
Idler Shaft Bolts - M8 | 27 N-m (20 ft. lbs.) |
Idler Shaft Bolts - M10 | 52 N-m (40 ft. lbs.) |
Shift Tower Bolts 11 | 8 N-m (100 in. lbs.) |
Clutch Housing Bolts | 46 N-m (34 ft. lbs.) |
Transmission Bolts | 75 N-m (55 ft. lbs.) |
Skid Plate Bolts | 41 n-m (31 ft. lbs.) |
TransmissionMount Bolts | 54 N-m (40 ft. lbs.) |
Clutch Housing Bolts | 54-61 N-m (40-45 ft. lbs.) |
Crossmember to Frame Bolts | 61-75 N-m (44-55 ft. lbs.) |
Crossmember to Insulator Nuts | 54-61 N-m (40-45 ft. lbs.) |
Drain/Fill Plug | 9-27 N-m (14-20 ft. lbs.) |
Front to Rear Housing Bolts | 30-35 N-m (22-26 ft. lbs.) |
Front Bearing Retainer Bolts | 19-25 N-m (14-18 ft. lbs.) |
Idler Shaft Bolts | 19-25 N-m (14-18 ft. lbs.) |
Rear Bearing Retainer Bolts | 30-35 N-m (22-26 ft. lbs.) |
Shift Tower Bolts | 7-10 N-m (5-7 ft. lbs.) |
Slave Cylinder Nuts | 23 N-m (17 ft. lbs.) |
Transfer Case Nuts | 47 N-m (35 ft. lbs.) |
U-Joint Clamp Bolts | 19 N-m (14 ft. lbs.) |
Drain Plug | 30 N-m (22 ft. lbs.) |
Fill Plug | 30 N-m (22 ft. lbs.) |
Shift Tower Bolts | 10 N-m (7 ft. lbs.) |
Housing Bolts | 28 N-m (20 ft. lbs.) |
Input Shaft Retainer Bolts | 9 N-m (80 in. lbs.) |
Bearing Retainer Bolts | 10 N-m (88 in. lbs.) |
Shift Rail Support Bolts | 8 N-m (71 in. lbs.) |
Idler Gear Shaft Bolt | 20 N-m (15 ft. lbs.) |
Countershaft Bolt | 100 N-m (74 ft. lbs.) |
Transmission Mounting Bolts 2.4L | 75 N-m (55 ft. lbs.) |
Dust Shield 2.4L | 34 N-m (25 ft. lbs.) |
Transmission Mounting Bolts 4.0L | 37 N-m (27 ft. lbs.) |
Dust Shield 4.0L | 58 N-m (43 ft. lbs.) |
Torque Convertor Bolt | 31 N-m (23 ft. lbs.) |
Crossmember Bolt/Nut | 68 N-m (50 ft. lbs.) |
Driveplate to Crankshaft Bolt | 75 N-m (55 ft. lbs.) |
Front Band Reaction Plug | 17 N-m (13 ft. lbs.) |
Front Band Adj Locknut | 34 N-m (25 ft. lbs.) |
Park/Neutral Switch | 43 N-m (25 ft. lbs.) |
Fluid Pan Bolt | 17 N-m (13 ft. lbs.) |
Oil Pump Bolt | 20 N-m (15 ft. lbs.) |
Overrunning Clutch Cam Bolt | 17 N-m (13 ft. lbs.) |
Pressure Test Port Plug | 14 N-m (10 ft. lbs.) |
Reaction Shaft Support Bolt | 20 N-m (15ft. lbs.) |
Rear Band Locknut | 41 N-m (30 ft. lbs.) |
Speedometer Adapter Bolt | 11 N-m (8 ft. lbs.) |
Fluid Filter Screw | 4 N-m (35 in. lbs.) |
Valve Body to Case Bolt | 12 N-m (100 in. lbs.) |
Converter to Driveplate Bolt | 88 N-m (65 ft. lbs.) |
Fluid Filter to Valve Body Bolt | 5 N-m (45 in. lbs.) |
L/R Clutch Retainer to Case Bolt | 5 N-m (45 in. lbs.) |
Adapter/Extension Housing Bolt | 54 N-m (40 ft. lbs.) |
Manual Valve Lever to Manual Valve Bolt | 5 N-m (45 in. lbs.) |
Oil Pan to Case Bolt | 20 N-m (14.5 ft. lbs.) |
Oil Pump to Case Bolt | 30 N-m (265 in. lbs.) |
Park Sprag Retainer Bolt | 4.5 N-m (40 in. lbs.) |
Reaction Shaft Support Halves Bolt | 28 N-m (250 in. lbs.) |
Solenoid/Pressure Switch Assy to Valve Body Bolt | 5.5 N-m (50 in. lbs.) |
Valve Body to Case Bolt | 12 N-m (105 in. lbs.) |
Valve Body to Transfer Plate Bolt | 5 N-m (45 in. lbs.) |
Cooler Line Fitting | 47.5 N-m (35 ft. lbs.) |
Output Shaft Nut | 271 N-m (200 ft. lbs.) |
Pressure Tap Plug | 5 N-m (45 in. lbs.) |
Input Speed to Case Sensor Bolt | 9 N-m (80 in. lbs.) |
Output Speed to Case Sensor Bolt | 9 N-m (80 in. lbs.) |
Detent Plug | 16-24 N-m (12-18 ft. lbs.) |
Drain/Fill Plug | 20-34 N-m (15-20 ft. lbs.) |
Extension Housing Bolt | 35-46 N-m (26-34 ft. lbs.) |
Front Bearing Retainer Bolt | 21 N-m (16 ft. lbs.) |
Case Half Bolt | 27-34 N-m (20-25 ft. lbs.) |
Front Yoke Nut | 122-176 N-m (90-130 ft. lbs.) |
Range Lever Nut | 27-34 (20-25 ft. lbs.) |
Rear Retainer Bolt | 35-46 N-m (26-34 ft. lbs.) |
Mounting Nuts | 29-40 N-m (22-30 ft. lbs.) |
Indicator Switch | 20-34 N-m (15-25 ft. lbs.) |
Detent Plug | 16-25 N-m (12-18 ft. lbs.) |
Drain/Fill Plug | 20-34 N-m (15-25 ft. lbs.) |
Rear Extension Bolt | 16-24 N-m (12-18 ft. lbs.) |
Front Input Retainer Bolt | 21 N-m (16 ft. lbs.) |
Case Half Bolt | 20-27 N-m (15-20 ft. lbs.) |
Rear Companion Flange Nut | 258-312 N-m (190-230 ft. lbs.) |
Shift Lever Bolt | 20-34 N-m (15-25 ft. lbs.) |
Mounting Nuts | 30-41 N-m (20-30 ft. lbs.) |
U-Joint Bolt | 19 N-m (17 ft. lbs.) |
Sector Support | 27-42 N-m (20-30 ft. lbs.) |
Transfer Case Position Sensor | 20-34 N-m (16-25 ft. lbs.) |
Speed Sensor Bolt | 11-16 N-m (8-12 ft. lbs.) |
Lug Nut 1/2x20 with 60 degree cone | 115 - 156 N-m (85 - 115 ft. lbs.) |
