This thread should guide you through replacing the water pump and thermostat (optional) on your Jeep Wrangler TJ.
Before reading this thread, please take a look at this thread as well, since it's very informative:
Jeep Wrangler TJ Cooling System Overhaul FAQ
Hardware Needed:
You can also find the part numbers listed below each item (broken down by year and engine), as well as a link to purchase them on Amazon and support this forum in the process.
Note that the majority of the parts I am linking to below are OE Mopar parts. I can't stress enough that you use OE Mopar parts (especially in regards to the water pump) when it comes to replacing anything in your cooling system. There have been so many documented issues with water pumps and other cooling system replacement parts purchased from AutoZone, O'Reiley's, and other local auto part stores. The replacement parts they sell you are sub-par, cheap Chinese crap. Save yourself the hassle of having to do the job twice and stick with OE Mopar parts (which I've linked to below). They may cost more, but believe me when I say, it's worth it, especially in regards to something as important as your cooling system.
Procedure
I'm not going to bother typing it out. In this say and age, we have something marvelous called YouTube (and videos in general). That being said, check out this step-by-step video on how to replace the water pump in your Jeep Wrangler TJ:
Hardware Needed:
- Water Pump and Gasket (gasket is included with new factory water pump)
97-02 4 cylinder: 4626054AF
03-06 4 cylinder: 4694307AF
97-99 6 cylinder: 4626054AF
00-06 6 cylinder: 5012366AG
- Thermostat
97-02 4 cylinder: 52028186AC
03-06 4 cylinder: 53010552AC
97-99 6 cylinder: 52028186AC
00-06 6 cylinder: 52028186AC
- Thermostat Housing and Gasket
97-06 (all engines): 53006192
- Mopar Upper Radiator Hose
97-06 (6 cylinder): 52028264AB
93-06 (4 cylinder): 52080030AD
97-02 (4 cylinder): 52028266 - Mopar Lower Radiator Hose
97-06 (6 cylinder): 52028265AD
03-06 (4 cylinder): 52080031AD
00-02 (4 cylinder): 52028141
97-99 (4 cylinder): 52079670AA
- Thread sealant with teflon
- NO RTV Required
- Optional: Serpentine belt, heater hoses
- Factory Service Manual (FSM) used for torque settings
- 1/2" Breaker Bar
- Inch lbs. Torque Wrench
- Middle Range Torque Wrench
- 11mm socket
- 13mm socket
- 14mm socket
- Gasket Scraper
- Wire Brush
- Channel Locks
- Large Crescent
- Optional: Stant Pressure Tester
Procedure
