Crank sensor for the flywheel is mocked up. I made a template that locks into a dowel pin and a bellhousing bolt. The template aligns the sensor to the proper location on the 6R80 transmission bellhousing. Then it's a simple drill and tap routine. Screw the sensor in until it bottoms out and back out a half turn. It should work as good if not better than the oem system.
