I installed this new "steering stabilizer" today. It makes the turns better.
Quite the intricate steering stabilizer
Very similar to a hydro assist setup
Jokes aside is that a stock tapped box? any steering fluid cooler setup on your rig,im sure your grill is a little crammed because of all the awesomeness you got going on in the front !
I got a PSC box laying around just need the hydro assist combined for when i go with bigger tires,still kinda need it now but i'll be fine ! Once i do go hydro assist im thinking about Blaines cooler setup with the passive cooler that gets tied into the grill/rad core support V bar but ill see. Time will tell
It's a stock box I tapped. I have a cooler in the grille above my heat exchanger. I'm also running a filter setup that helps cool it as well. The big bore boxes are nice, but pricey.
Awesome!
Yeah i kinda got lucky with my Psc box since i got it for about 580 if i remember correctly but no more than that ! When i find deals and have enough i'll strike......even if it means being short on cash for a little bit
Edit - Is it the same ford filter that you're using on your transmission ?
It's an Allison spin on filter used in some of the GM vehicles. It's a good filter for hydraulic stuff with a low micron rating and a magnet inside.
Is this something I could run to help cool the 42RLE?
Crappy parts saga the II. Brand new set of King main bearings from Summit. No tab on one of the cap side shells. Junk...
I'll be damned QC Ain't up to par now days it seems...
If im correct engine tech bearings are made from king so if anything you could try them ? Or exchange the same ones for another set of the same thing ?
Edit- Are Clevite bearings any good ?
I run one on my trans as well. I'm not sure how much it really affects the cooling besides a small amount of added volume and the surface area of the housing, filter and lines. Certainly less effective than even a cheap cooler.
A possible future project. I picked it up cheap, presumably because no one has been able to swap one yet. I have no plans to do anything with it anytime soon, except to maybe get it running on the stand.
That's the 3.0, right?A possible future project. I picked it up cheap, presumably because no one has been able to swap one yet. I have no plans to do anything with it anytime soon, except to maybe get it running on the stand.
Once upon a time I owned an F350 and was an active member of a Powerstroke forum. We had a gathering at Pismo Beach. One guy brought a TJ with a 6.0 swap. I have no idea how it handled with that much weight up front, but he was hauling butt through the dunes. It sounded awesome.
I'm very interested in how you're going to deal with making the pcm happy. I'd love to have a baby duramax
