Some progress today but not to the extent I was looking for. I drove a bit this morning trying to find some 3/16” steel at local stores to start redoing my rear cross member. Nothing. When I got home I was rummaging through my scraps and found some 11gauge that I had and were a decent size that would work for my body mounts. When I started mocking up I realized the bolts were too long bc of the 1.25” body lift I have. So another trip to the store for some shorter 7/16 threaded bolts. The results of my rear crossmember.
It came out better than I expected it would. I had some 3/16” steel that came with my GR 3 Link that I won’t use so used this to fill in for the gap in the body mounts when tightened and installed. Works perfectly. I was hoping to get it all welded up today as well as finish welding the towers but, no bueno. I had to throw the axle back under the jeep to make sure the new crossmember didn’t hit the upper axle brackets, so that took a lot of time. But…
Plan tomorrow is to weld in everything tomorrow.
And I bolted in the BM tail lights. These things look so good!
Oh my gosh I was just thinking of doing a cross member like that and couldn’t find anything online of people doing it simple for just the body mounts. Looks great!
Nice work. Interested to see how you like the ORI's. I have a few hard core buddies that run them, and they seem to work very well.
Hectic week at work so didn't get much done during the week, but did finally get some tracking numbers for the front brake setup and a few other items. I planned to start mounting the Synergy knuckles and RPM steering this week but when I was putting it together, the upper knuckle mount was massive. I guess it needs a camber sleeve for the upper knuckle to ball joint.
So placed an order from poly performance and decided to get some PRP 4 point harnesses as well. I got the 4.3 for myself and the 4.2 for my passengers. I often ride alone so figured I'd save a little money. The difference between the two is the 4.3" has 3" straps where the 4.2" has the 2". This is also came in yesterday.
I don't plan to go hydro assist yet. But by the end of the year I hope to purchase and install the rest of the components. I figured this will be a good first step. The pitman arm is from parts mike drilled with a JK taper at the same length as the stock TJ pitman arm 5.5".
A month or so ago, I posted my 4" flare GR fenders on FB marketplace to see if I got any hits. Reason being, I wanted to go with the no flare. Well last week I had a guy message me asking if I wanted to trade for some GR no flare fenders. I was on it quick, but because of our busy schedule we couldn't meet up til yesterday evening. 1.5hr drive later and these will be the new fender. I think it'll look better without a flare since I won't be using rear flares. Plus, NC doesn't give two shits about tire coverage. At least I've never had an issue.
Today I put in some work finishing up grinding down the old front spring buckets and towers and found a good spot for the from GR frame mounts. This is at about 103" wheelbase.
My little chili pepper red TJ in the background sad since it hasn't gotten much love bc of my TJ. I do have some savvy CA's that I need to rebuild, and some RCV shafts that also need rebuilding that will go on the red TJ, it just has to wait its turn.
Tonight, I finally pulled out the GR universal coil-over mounts to take inventory and see how I'm going to attack the front. Will be a fun time. I've gone through NashvilleTJ's, Toximus's, and B00mB00m's thread but still reading to see what tricks and tips I can take away before I start it. I still haven't figured out what the hell I'm going to do with the front trackbar. Straight, bent, location on frame, what size to Dom to go with, Johnny joint or heim at the frame. lost of questions or trial and error to see what will be best for me.
And finally, just a funny here to honor the passing of everyone's hero, Chuck Norris. Enjoy haha
Tower on frame:I’m going with rpm steering components and synergy hi steers knuckles. My camber sleeves come in Wednesday so won’t be able to assemble everything until then. I will most likely buy a HF tube bender but waiting. I’ve read an old post on pirate4by4 of Blaine’s that says if going straight trackbar, a 1 1/4” by 0.12 wall tube will do just fine, but if any bends in it, then a 1 1/2” by .25 wall tube would be ideal.
My initial full bump looks like bends in my trackbar may be beneficial to uptravel.
Yes it does thank you. Are you using the TNT steering box flip kit?
A little progress and dilemma this weekend. Progress was mocking up the pvc arms and tacking in the lower axle mounts. Lowers will be 22 1/4” and upper will be 33”. I’ll confirm today when I get home but plan to order them this weekend through wide open design. The lowers will be 2” and upper will be 1.75”. I thought I could get away with 2” all the way around but there is no way a 2” link will fit with where full bump is right now.
The goal for the front is to stretch as far a possible. As of right now that is looking like right under 3”. But the dilemma is at around 5” up, the upper Mount hits the lower radiator hose. I could maybe cut down the hose just a bit at the radiator to move it forward a little or I could push the axle back about .5” to get a little more clearance. But even after that, the trackbar will most likely get into the hose especially after I put some bends in it.
What to do what to do..![]()
