I believe the covers are interchangeable, although one company noted that different years will have different lips overhanging the case, as if to imply the bolt pattern and arrangement is similar but not thickness or sizing wise. Here’s some more info I found!Pretty interesting. Do they still fit in the same case? Or does the JK have a special cover?
“The carrier bearings are slightly larger in diameter with the new generation Dana 44 found in Rubicon models. Another difference is found in the design of the differential. The cross-pin in the Rubicon next-gen 44 is not in the same place as the first gen, requiring different length axleshafts. The Rubicon model next-gen 44 front axleshafts also used larger steering joints and had more beef around the joints. The non-Rubicon JKs only came with a Dana 44 rear axle. The differential and carrier bearings in the non-Rubicon models are the same as the older generation 44s.”
