MaritimeTJ
How is the firewall clearance with the motor? I am assuming your placement of the motor was probably more so based on the GM trans fitting in the tunnel?
Just watched it. Good job, very thorough start to the swap. Lots to think about.Ok, part 1 of my swap series is up, I'm new to video editing so I kept it simple, it's a long first video but it is what it is, put it on 1.5x to make it more bearable! This one is just about planning and the initial tear down. I'll get the rest of them done over the next few weeks.
Love the Lokar. I have the same one for my YJ 4L80E swap to mimic the factory style shifter.Here are a few update photos of the rig.
More pics of the oil pan. Are you running a low clearance swap pan or are you still running the factory 5.3 pan?Here are a few update photos of the rig.
I'm running stock oil pan.More pics of the oil pan. Are you running a low clearance swap pan or are you still running the factory 5.3 pan?
How tight was the motor mount to header clearances? Sandersons right?
I have seen photos and videos from folks running that same setup and the collector is tight between the engine mount, frame, and collector.
Glad you enjoy them. I'm noticing your profile says you joined Jan 17th of this year and you have 5x the amount of messages as me, you are a busy dude!I’ve watched up through 4. Good job.
Exactly the opposite. Not busy. Finally warming up enough to work on the jeep.Glad you enjoy them. I'm noticing your profile says you joined Jan 17th of this year and you have 5x the amount of messages as me, you are a busy dude!
