I love my TJ.
Here is how I use my TJ:
I like to off road alone or with my family. I know this can be a really bad idea, but for us, its about fun destinations rather than the journey.
A winch:
I love the safety factor of having a winch. I hate the idea of buying a $500 + piece of equipment on my front bumper, to be destroyed in a matter of years by Michigan salt, and being lucky to be used a few times a year. I feel like I would be throwing away money.
The king of come-alongs:
Wyeth Scott- love the synthetic. Love the quality. Hesitant about the physical size, and the cost is the same a a winch. Also the 35ft, which is a good start. The 2 ton version, is the same size as the 3 ton, so its cheaper, but still takes up valuable trunk space.
The $50 4 ton come-along.
So, not really the 4 ton, but if you use it as a 2 ton with out the snatch block.... 12ft of working length is a decent start?? A tight steel cable in your face, is not enjoyable. I get nervous when that line gets really taught.
Scenarios:
So, here is my idea.
I think 2 tons will be the help needed, it most situations, to recover my jeep.
So... any thoughts?
I would love it if I could use the winch as a traction winch. Tension on the back end of the rope, say 6 wraps to achieve the necessary friction and unlimited pull length.... but I don't see it being done...
- Daily Driver. I drive it every day. I drive it in a Michigan winter but wash it a lot. I have the top off as much as possible in the summer.
- Being a mechanical engineer I find things to fix on my TJ and could not be more happy working on my jeep in the garage.
- Helping someone stuck in snow, occasional off roading. I would like to enjoy trails but there is no where to go where i live.
- I have with me at all times, a 20ft kinetic rope, 20ft recovery strap, shackles, hitch pin, front tow hooks, tools, soft shackle.
- I have open diffs, a 2 inch lift, and 31's. Not any different than stock.
- I don't like clubs (because of bad experiences with the whole tread lightly thing)
- In 2 years, I have had the jeep on trails 3 times. In SW Michigan, I have to drive 45 min just to find basic two tracks. There is little around me.
- I am not a fan of mud. I go through it to get through it. I don't seek it. Point being, I am conservative.
A winch:
Scenarios:
- Drive too far into mud. Can't back out. Using traction boards and a shovel to help start the recovery.
- Ground an axle or frame causing 1 wheel off the ground, and the opposite wheel, not enough traction. (yes lockers would solve this)
- Slide off a snowy trail into the ditch.
- I would like to buy a $50 come along and equip it with 50 ft of 1/4 synthetic rope.
- Synthetic rope 1/4" has about a 7000 breaking strength.
- I understand that I can only spool say 12 feet and I would have to manage the remaining rope.
- I would make sure to modify / check the come along for anything that would cut the rope.
- I think wrap a recovery strap around my anchor (tree). Depending on how many wraps around the tree, would give me the ability to remove slack in the come along.
- Attach the come along to the recover strap and the long lead would then go to the jeep. This keeps me away from the mud and the moving jeep.
So... any thoughts?
