When I bought my '05 Rubicon it had a K&N filter system installed. I knew little about these, other than they needed regular cleaning. Not knowing when it was last cleaned, I got some K&N cleaner and oil and went to work. I cleaned and rinsed it and set it in the sun to dry. I was surprised to see light was able to penetrate the filter, unlike any other disposable filter I've ever seen. After searching the infowebs for some info on the K&N filters I discovered that in some tests they were pretty poor at filtering the air entering the engine. Not too surprising since I could see light through mine.
Is anyone aware of a replacement filter for the K&N intake that offers better air filtration than the K&N filter? I don't want to replace the entire air system with a stock unit, but will if necessary.
