After discovering a broken actuator pin, I replaced that part a month or so ago. Since then, the key-in chime has not worked.
"ON" position: Chime works
"Key-In" position: Chime doesn't work
"Accessory" position: Chime doesn't work
While the key is in one of the two positions that the chime doesn't work, I can push inward on the lock cylinder and the chime works, until I release. I get the feeling there's a simple explanation, only I've not thought of it. I'm at a loss, here.
Here's a video
The one thing that I am unsure about is the hole that is on the opposite end of the (oem) lock cylinder. In that hole, there is a loosely fitting plastic pin that contacts with the actuator pin, compresses and activates the chime. I'm wondering if that pin's length has anything to do with it. Aside from that, I'm stumped until I can get back to it tomorrow.
Here's a video
