Knocking from front of engine bay
4l4life
Portland
I got a 97 tj sport manual with a freshly rebuilt head. A knocking noise has made itself apparent starting a couple months ago but has gone from partial noise to constant knocking. It’s residual as long as it’s running, it gets faster when I accelerate. I think the noise is closest to the front by the power steering reservoir
  • 68047563244__F1961778-65A2-4A05-8A9D-B3C84D8F33E7.MOV
    1 MB
pagrey
TJ Guru
Los Angeles, CA, USA
Sounds quiet to me but I'd check the timing chain. On a 4.0 a loose chain sounds more like a knock then the rattle of a chain. It's easy to check moving the crank and feeling for play.
4l4life
4l4life
Portland
Ok so update, belts pulled.timing pulley has 0 play. All the other pulleys spin and the power steering pulley has a little resistance and doesn’t come close to making a full rotation once spun
kincaid.0678
Martinsburg, WV
Have you checked for exhaust leaks? It’s hard to hear well In the video but I know it can sound like a ticking or tapping sound. You had your head off so the manifold was too. When I replaced my manifold and gasket I had the bolts loosen up and cause a leak. Had to re torque them with some medium thread locker
4l4life
4l4life
Portland
I’ll give that a shot, the wierd thing is it’s just coming from the far front by the power steering housing in the engine. Is that noise from the PS housing normal?
JKP
Warner Robins GA
Pull the belt and start it up. If it still makes the noise, not the accessory drive.
Won't hurt anything to run it for a min or two.
