That's actually closer to reality than not.Save them for the next grade 2 fastener you use
You clearly do not understand how bolts work then.
The magnitude of the shear yield stress in pure shear is (√3) times lower than the tensile yield stress in the case of simple tension.
Define more.Please explain how a bolt in double shear (or single shear for that matter) resists a greater force when more torque is applied to the nut.
Define more.
Those are not slip critical connections. We use bolts in vehicles and fabrication almost solely in slip critical connections where if the shank of the bolt ever sees shear forces, it is considered a failed connection.I don't know if I can explain it any simpler than that. There are basically two different types of forces that can act on a bolt:
1. Shear is a force that tries to cut a bolt across the shaft. Think cutting a wire with a wire cutter.
2. Tension is a force that tries to pull the bolt apart lengthwise. Think taking that same wire grabbing it a both ends and pulling in opposite directions.
The more you torque a bolt the greater its clamping force which is great if the goal is one of two things:
1. To bring two (or more) surfaces into as complete a contact as possible. For instance a wheel to a hub or a head to a block with a planed mating surface and a gasket.
2. In a type of bolted connection known as a Friction connection where the friction between the two surfaces resist the load, however friction connections are seldom used in steel design anymore because the value of friction connections are always less then the value of the bolt in simple shear.
Which brings me back to the subject of shear connections:
A simple shear connection is a bolt (or a pin... More on that later.) going through two pieces of material pulling (or pushing) in opposite directions. All force is applied to only one plane across the bolt shaft.
A double shear connection is where you have 3 pieces of material two applying force in one direction and one applying force in the opposite direction. This divides the force applied to the bolt shaft into two equal shear planes that are half the force applied. This is why a bolt in double shear is twice as strong as a bolt in single shear. A shock bolt is in double shear for instance.
Which brings me back to shear and the need for torque in a shear connection. In structural steel applications a vast majority of simple framed bolted connections are designed for shear using high-strength A325 or A490 bolts. Most of those are designated as shear connections solely dependent on the strength of the shaft to resist the shearing force of two pieces of steel. (There are connections where the threads of the bolt are included in the shear plane and those of a higher capacity where the threads of the bolt are excluded from the shear plane, but that is another conversation.)
All of those bolts are indeed torqued using visual indicators so that all plies of steel are brought firmly in contact with each other and to prevent the bolt from backing off. So the bolt is indeed pre-tensioned, however that is not done to increase the shear value of the bolt. There are many applications using shear connections where bolts are specifically not torqued and are simply hand tightened and the nuts are "killed" using either a weld stinger or a cold chisel. These connections have the same value as the torqued connections. I could also use pinned shear connections as an example. There are many extremely heavily loaded connections in structures such as bridges, conveyors and cranes that have no bolts in them only shear pins with only a washer and a cotter pin to hold them in place and zero torque applied to the shaft.
Sorry for the long post, I just finished my first cup of coffee.
That's a gorgeous Jeep my friend!It surprises me how many mechanical engineers do not understand how bolts work. We will get an assembly that has a 20mm bolt in it and I bitch because it needs to be tightened to 300 plus foot lbs. Engineer that designed it says just tighten it up with loctite. I say how tight. He says till it feels right. Then I call him a fucking idiot and I get talked to by my boss.
For those that do not understand, bolts need to stretch to apply the proper clamp load they are 'designed' to hold. A good book to read is Carrol Smith's Engineer To Win. Talks about how stuff should be welded, bolted, and riveted together for race cars. It applies to jeeps too.
You can quit being a dickhead and try to learn something just about any time now. I promise it won't fucking hurt a bit.I feel a little better knowing that John Currie and myself don't understand how bolts work.
In fact, your entire post is yet another example of knowledge not equaling understanding. You have an admirable amount knowledge about connections used in structural building. You have completely overlooked the single key difference in why each type is used. Understanding failed.
Alright, this deals with the most common connection we deal with. In context, this is an automotive related site, we discuss automotive related things along with fabrication of various items we use. The vast majority of bolted connections we use and the one that started this post is a slip critical that relies on the friction developed between the faying surfaces to lock the bolted members in place. In that type connection, the bolts sees very little of the load when it is torqued properly and at the point when the bolt does see the forces, we can consider the connection failed.I did my job of explaining, and took time out of my day to do it. All you have done is say that "people don't understand" but have failed to explain your side of the debate. Your comment, "Understanding failed." is not a convincing debate point. I refer to my previous post as a very detailed explanation as to how bolts work in any type of connection. Shear vs Friction vs Tension. Please convince me and others differently with facts instead of rhetoric...
The basic premise of the first post in this thread is that, "People are dumb asses, because they don't understand how bolts work," but you haven't provided any proof.
By the way... A bolt will NEVER have a higher value in friction than it does in shear.
We do not use snug tight single or double shear connections for cyclical loading so how they work has no relevance.
This will help.
https://www.boltscience.com/pages/the-basics-of-bolted-joints.pdf
This will help.
When it comes to the coilover spacers, does this mean the friction between the spacer and the mount takes the force from the coilover? The bolt doesn’t take any shear stress?
We use air shocks on our race buggies in a similar fashion and I’d always thought the bolt takes the force. We use the air shocks as bump stops as well so it might be slightly different than a Jeep with separate bump stops.
