@Plumber1 would be really proud-
If you don’t have access to the race
from the other side or don’t want to risk damage to the internals banging around, this works -
Way too much hammer.
Maybe next time just pour some liquid nitrogen on the race to make it shrink. Work smarter not harder.
If you don’t have access to the race View attachment 536199 from the other side or don’t want to risk damage to the internals banging around, this works -
No slide hammer? Like the ingenuity though
Heat and cold both do the same thing. Run a weld bead around the tapered bit of the race and when you're done, the race will fall right out. (not really the heat, the weld shrinking does the work) If I have to tell you to protect the seal bore from weld spatter, you shouldn't be doing this anyway.
I like your thinking outside of the box. A tool is tool no matter how you use it. Now I'm not calling you a tool
I can't tell you how many times a pipe wrench has been used a hammer, or a 14" wrench made into a 24"
I wish I could buy a pipe wrench for $23.00 but mine run about $69.00
https://www.amazon.com/Ridgid-R31095-Aluminum-Straight-Wrench/dp/B0155AGBNO/?tag=wranglerorg-20
I guess no harbor freights in California?
Oh yea HF is great for tools used around the house not so good for professional use everyday. IMHO
WOW, and from a Alabama guy ! I'm impressed Andy![]()
