I spend my free time playing guitar / mandolin
Of course I will watch an occasional YouTube video on how-to fix something, I just make sure not to get sucked into anything else, haha.
I’ve seen a couple videos. He sure is expensive. Glad there’s people out there who will do this kind of stuff for free.
Backing up, leaving slack and flooring it to jerk the other vehicle is every kind of wrong.
If it’s kinetic. It didn’t look kinetic to me.That's exactly how recovery ropes are supposed to be used though.
Well then, I stand corrected. Nice pullIt's a Yankum Rope.
He runs a very large towing company down in S UT. The Cherokee is a purpose built tow rig to pull the idiots that think they are invulnerable from where they shouldn't be. Both ends of his XJ are equipped with receivers and electrical connections so he can use his winch from either end.Backing up, leaving slack and flooring it to jerk the other vehicle is every kind of wrong.
His tow hooks were dangerous. At least he hooked them on the right way.
His pulling from the hitch was dangerous. They’re not rated for those forces.
He might think about getting a winch so he can accomplish controlled recoveries that are safe.
Interesting, how do you setup bevel gears to operate under high torque in reverse direction?He also explained in one of his videos why he occasionally does a pull in reverse. And how his rig is set up to do so.
That I cant say, I dont really know a whole lot about how that stuff works yet. And I can't remember his explanation. I searched for that particular vid for a bit but didnt find it again.Interesting, how do you setup bevel gears to operate under high torque in reverse direction?
Not sure what his running but the high pinion is the same only running in reverse with the pinion at the top of the ring. t's favored for reducing the front drive shaft angle and clearance.high pinion axle he's running in the front
The shear rating on a SAE Class 3 ball shank is over 46,000 lbs.
