Its a big chunk of metal, maybe its a southern thing???
oh and pumpkin....
I thought that was a name used for a penis...............or Kevin Jonas.
Think i found the culprit, and its not the water pump. Finally was able to crawl under it after a short trip and found what looks like a slice on the lower radiator hose. I cleaned it up and took another short drive, but can not get it to leak again. Going to let her cool down then take another short trip as it seems to do it an the first short trip when its cold and gets to temp, but not once its at temp. Weird
It sure looks like you found the leak. I'm wondering if the right hose was installed there. It seems to be sticking out further than it should which apparently caused that slit.
It’s been my experience that auto store hoses are always a bit longer than required, just trim to fit. Your wallet is happy you didn’t shoot the parts cannon at the leak. A pressure test is an easy way to find a leak. I always run a dye in my coolant and engine oil for quick diagnosis as well.
