Flushing the coolant system, I first removed the thermostat. Did the Prestone, flushed, then Thermocure and flushed again. Three times I've removed/replaced the thermostat housing and it continues to leak.
1. Didn't use RTV for the flush. Noticed a leak but wasn't concerned since I was going to replace again with a thermostat.
2. Gasket came with adhesive on one side so I used that and a thin line of black RTV on the other side. Leaked bad.
3. Removed and cleaned the housing and tried again with a new gasket and more black RTV. Still leaking.
4. Removed again. Gasket seemed well attached to engine side so I cleaned the housing surface and spread gray thermostat RTV on the mating surface and reinstalled. Waited overnight to refill and it's pouring out the bottom.
Can't really tell where it's coming from, looks to be the bottom bolt.
Help!
Help!
