Least expensive scan tool that does everything
jrfuda
Fayetteville, NC
I've been reading through the various scan tool threads after going down the rabbit hole of reading the OPDA and Camshaft position sensor threads. I installed a Crown OPDA today during my build and broke my stuck cam position sensor, so I am going to have to use the Crown sensor or another aftermarket sensor (Napa?). Anticipating issues when I get the TJ running again in a month or so (it's in pieces), but I want to be prepared and at least have a starting point.
What is the least expensive solution that will allow you to do everything you possibly would want a scan tool to do? I compiled a list below of scan tools I've seen mentioned here.
I currently have a BAFX Product 34t5 "ELM 327 Compatible" OBDII Scanner that I use with Torque Pro that I've owned for a while, long before I ever got my TJ. I know I can reset the check engine light with it and clear codes, but I do not think it can do the relearn or that it can tell me the difference numbers in something other than hex (based on posts here).
One Amazon, I put in various combos of "TJ" and "Wrangler" in the "ask Rufus" box to see what their AI had to say about the products I found mentioned in various threads on this forum.
EDIT: I have a 2005 LJ, despite Rufus spitting out random other years and models when it gives me an answer
I had high hopes for the ThinkDiag2 handheld ($160) and Bluetooth only version, but saw they require a subscription after a year. Rufus says "The Thinkdiag OBD2 scanner can regulate idle speed and perform other functions like ABS bleeding, injector coding, and SAS reset on a 2004 Jeep Wrangler TJ, as evidenced by customer questions and answers".
Kingbolen ($145) appears to be a clone of the ThinkDiag2 and also requires a subscription. Rufus says "I did not find any reviews explicitly mentioning compatibility with the Wrangler TJ model. However, the product description states it works with 1996 and newer vehicles from 120+ brands, which would likely include the 1997-2006 Jeep Wrangler TJ".
Innova 5610 is not crazy expensive ($250), but I think I only saw one person mention it worked, and it was for the camshaft sensor relearn. Rufus says "The Innova 5610 bidirectional scan tool can command and test functions on a 1997-2006 Jeep Wrangler TJ, such as operating the fuel pump, retracting the electronic parking brake, and performing bidirectional controls to pinpoint issues. According to the product description, it works on all 1996 and newer OBD2 vehicles."
Inova 5410 is a little less ($179), but it has also only been mentioned once here and the user was "happy with it." Rufus says "The product information shows that it works on a 2006 Jeep Wrangler, but does not specifically mention a 2009 Jeep Wrangler TJ. However, one customer report using it successfully on their 2006 Jeep Wrangler".
FOXWELL NT510 Elite ($200) claims it can do it all, but I think I've only seen it mentioned once here. Rufus says "The Foxwell NT510 Elite can read and clear codes, perform bi-directional control tests, and provide live data streams for all systems on 1999-2006 Jeep Wrangler TJs. However, it cannot diagnose or program the ECM/PCM or relearn transmissions on these vehicles".
Zurich ($160) from Harbor Freight has some mentions here, but I'm not sure what it can do.
Autel Devices (Comparison chart here). Has a subscription for updates (new care models) but not for functionality.
Autel MaxiCom MK808S ($480)is the most expensive beside a DRBIII but sounds like it does it all based on forum posts. Rufus says "I did not find any reviews mentioning support for a 1997-2006 Jeep Wrangler TJ. However, the product information shows it supports 2007-2021 Jeep Wrangler vehicles. To confirm compatibility for your 1997 Wrangler TJ, I recommend reaching out to the manufacturer or consulting their online vehicle coverage tool." EDIT: Newegg (third party seller, so beware) appears to have it for $369 https://www.newegg.com/p/0AF-01XB-00007
Autel MaxiCom MK808BT PRO/ MK808Z-BT/MK808K-BT $550) Adds Battery Analysis and Bluetooth Connectivity to vehicle
Autel MaxiCom MK808S-TS ($650) Adds battery Analysis, Bluetooth Connectivity to vehicle, Complete Immobilizer function, Advanced TPMS functions and activation, Programming of Autel MC Sensor, Comprehensive OBD relearn coverage, and on-screen relearn procedure
Autel MaxiCheck MX808S-TS ($550) is supposedly "Same as MX900-TS TS900, US Ver. of MaxiCOM MK808S-TS MK808Z-TS Upgrade of MK808S MK808Z" Even the Autel site seems to confirm this as the comparison chart matches the Maxicon model. In fact, it appears the MaxiCheck versions of all the deives are $100 cheaper (have MX instead of MK prefix on model number). I'll need to check if there are any other issues with getting these "US version" instead of the others... maybe the subscription is more. EDIT: It appears the MaxiCheck devices are normally the same price as the MaxiCom devices, but one of the sellers has it on sale. The two main sellers appear to be AutelTech and AutelUS - both appear to be authorized sellers in the US. Both ship from Amazon. AutelUS currently has a lightening deal going on their devices, hence the lower price.
EDIT: I'll add more devices as they are posted, or I stumble on them. Everything below here was added after the initial post
ICON T7 ($400) from Harbor Freight comes up when you search for the Autel MK808S. There are no mentions on the forums. One reviewer on HF said "Incredibly impressed with this scanner for the price. It's scans faster than expected and haven't found a obd2 vehicle it won't read yet. Has almost all of the features of my friends autel 906 except for a camera and oscilloscope. Surprisingly the screen is clear enough to read wiring diagrams from alldata. Couldn't find a more versatile scanner for under 500 dollars."
There is also the DRB III emulator thread, started by @AndyA but it appears the needed hardware is no longer available... Searching for Micropod 2 has tons of hits and makes it appear to be available, but the thread implies the currently available hardware does not work.
XTool D8 looks like it is no longer for sale, but there are two updated version the D8W ($700) and D8S ($650). I do not see it mentioned in the forum other than the recommendation from @DuckNut below. They both appear well-reviewed and have pretty big coupons at the moment ($120 each). Rufus says "The XTOOL D8S supports full system diagnostics and bi-directional control for the 1997-2006 Jeep Wrangler TJ. It can perform active tests and access modules like the engine, transmission, ABS, SRS, body control module and more. Common services it can perform include oil reset, EPB reset, SAS calibration, BMS reset, throttle relearn and injector coding. However, I recommend checking compatibility with your specific TJ model year and required functions before purchasing" and for the D8W "I did not find any reviews mentioning compatibility with the Wrangler TJ model. However, the product description states that the XTOOL D8W can perform full system diagnostics and bi-directional control on vehicles from various manufacturers".
Reactions: lBasket
The Kingbolen ($145) appears to be a clone of the ThinkDiag2 and also requires a subscription. Rufus says "I did not find any reviews explicitly mentioning compatibility with the Wrangler TJ model. However, the product description states it works with 1996 and newer vehicles from 120+ brands, which would likely include the 1997-2006 Jeep Wrangler TJ".
The Innova 5610 is not crazy expensive ($250), but I think I only saw one person mention it worked, and it was for the camshaft sensor relearn. Rufus says "The Innova 5610 bidirectional scan tool can command and test functions on a 1997-2006 Jeep Wrangler TJ, such as operating the fuel pump, retracting the electronic parking brake, and performing bidirectional controls to pinpoint issues. According to the product description, it works on all 1996 and newer OBD2 vehicles."
The Inova 5410 is a little less ($179), but it has also only been mentioned once here and the user was "happy with it." Rufus says "The product information shows that it works on a 2006 Jeep Wrangler, but does not specifically mention a 2009 Jeep Wrangler TJ. However, one customer report using it successfully on their 2006 Jeep Wrangler".
The FOXWELL NT510 Elite ($200) claims it can do it all, but I think I've only seen it mentioned once here. Rufus says "The Foxwell NT510 Elite can read and clear codes, perform bi-directional control tests, and provide live data streams for all systems on 1999-2006 Jeep Wrangler TJs. However, it cannot diagnose or program the ECM/PCM or relearn transmissions on these vehicles".
The Zurich ($160) from Harbor Freight has some mentions here, but I'm not sure what it can do.
The Autel ($480)is the most expensive beside a DRBIII but sounds like it does it all based on forum posts. Rufus says "I did not find any reviews mentioning support for a 1997-2006 Jeep Wrangler TJ. However, the product information shows it supports 2007-2021 Jeep Wrangler vehicles. To confirm compatibility for your 1997 Wrangler TJ, I recommend reaching out to the manufacturer or consulting their online vehicle coverage tool."
I've been watching the ThinkDiag2 and Autel in my amazon cart. Both go on sale regularly. The ThinkDiag can be had for $12X and the Autel I believe drops to under $400 at times.
I'm loathe to purchase anything that's based on a Chinese tablet and iteration of Android. Call me paranoid about cybersecurity.
I've heard good things about Innova but no first hand experience. I too am using a Bluetooth dongle and Torque Pro, and I too would love to up my game without breaking the bank.
-Mac
I bought the Autel MK808. If you watch you can get it for about $350. Came with a 1yr Sub. It works just fine with an expired subscription, just does not download any new updates for newer generation cars. Newest in my fleet is almost 10yrs old so I'm covered.
Paid for itself doing the Cam/Crank Re-Learn and Programming New Keys for my F250 over the Dealer. I had a Cummins and it would program Injector IQA codes. Definitely cheaper options out there, but lots of features for $400.
...Paid for itself doing the Cam/Crank Re-Learn and Programming New Keys for my F250 over the Dealer....
I am intrigued by this - will definitely help it pay for itself. I actually have to get new keys made for my fathers-in-law's old Ford Ranger as he only has one working coded key (has another key but it is not coded). If it can do that, that's like $90 saved right there plus all the time dealing with the dealership.
I bought a Autel MaxiCOM MK808BT PRO about a year ago. It's bi-directional, and I bought this for when I need to do a Cam/Crank Re-Learn when I replace my 20 year old sensors. They're after sales support is Awesome. They offered me a choice of a free item out of 4 choices. I also asked them for a large discount on another item, got that also!!
Reactions: Spike Strip
Added more info to the first thread regarding variations of the Autel devices. There are MaxiCom (MK prefix) and MaxiCheck (MX prefix) models that are supposedly the same, but the MaxiCheck is for US markets. I'm digging to see if there are other difference (maybe update subscription price)
#1 feature to look for in my opinion is the cam-crank relearn. Find the cheapest scanner that can do this, and everything else is just fluff. Otherwise you're going to pay stupid money to go to the dealership to have them do it.
No ELM based OBD-II scanner I've found has been able to do it. Neither does HP Tuners. But the cheap Autel Maxicom does it. Saved my bacon a number of times.
Reactions: jrfuda
Also I can confirm your Autel special functions (including cam-crank) will still work after your subscription expires. Most updates are just adding support for current model-year cars. Set a calendar reminder to turn it on and update everything a couple days before your subscription expires.
Recently got the Topdon Top Scan. It’s Bluetooth and you use with an IOS or Android phone. It’s cheap (under $100) but it’s subscription based. Comes with 1st year but after that was like another $100 per year. Can’t remember exactly but I was ok with it.
I purchased to chase down an emissions issue on a Honda and it worked way better than my cheap Autel. I did scan some of my other vehicles including my 2006 LJ. No issues with the Jeep so no codes. I will say though that this scanner only found 2 out of over a dozen modules it can scan. I didn’t think much of that since these old jeeps are pretty simple.
Reactions: rauljr98
I ended up getting an Autel MaxiCheck MX808S-TS. I tried to program keys for my father in law's ranger but his second key was not chipped so I could not confirm it worked.. did go through the whole programming process before I realized the key was not chipped.
This morning I successfully did the cam crank position relearn with zero issues after starting my LJ for the first time in about a month after having it somewhat dissambled and swapping the opda among other things. I had to use the crown sensor as my oem sensor broke when I tried to remove it. Hopefully the relearn will keep it from malfunctioning.
If you do not care about the chip you can bypass it as long as you have 1 chipped key. DM me and I'll tell you how.
I have an Autel 835b (I think). Works good when it works. When I need it I find that it has shut down. I have to get on the phone with tech support and a computer and download the latest updates. Yup, when there are updates the entire machine is rendered useless until the updates are installed.
Reactions: jrfuda
Thanks. It will probably be Easter before I'm back at their house. I'll DM you in the interim for the instructions. I think I saw something among the tools to erase all the keys when I was trying to program the unchipped key but was afraid to try it.
Can it program keys for a jeep tj????
