LED backup lights
Claytone
10001110101
Centennial, CO
Price
$22 or $30
Centennial CO
Price update, $32 shipped due to postage increase. Each addl pair is $22 more, no extra shipping.
***See the last posting page for the latest availability. My parts come in so slowly that I don't want to have a long list again. When I get these parts and make a few, I open it back up. When that quantity is sold I'll change the thread back to closed until I can make more.***
Selling a pair of bright LEDs that fit inside the stock TJ tail light housing.
They mount on the sheet metal housing separator plate. I’ll include a proper sized nail that works as a transfer punch to mark where you drill the mounting holes.
Plug the connector into the reverse bulb socket, no wiring alterations required.
These have a nice heat sink and get pretty warm in operation.
The pair draws around 1.6 amps.
$22 for local pickup and $32 shipped in a small USPS flat rate box.
One side installed for comparison
The plate with the 11/64 drilled holes in it, and the high tech transfer punch.
I put the light in so that the edge of the LED lens was even with the metal plate. Your install depth may vary depending on clearance to the tail light cover. Mine just touches it, but doesn’t push it off the seal.
Depending on your housing, you may need to bend this bulb holder tab back towards the body for clearance. I had to on one side of mine but not the other.
$22 for local
Sent you a PM. Thx
Hey all,
I’m new here. I just bought LED tail lights for my 98 tj and I was able to get my driver side working but the passenger side wires are different colors and they have 4 wires instead of 3. Not sure what to do. Please help! Photo attached.
Thank you,
-Rick
Looks like a trailer wiring harness.
