Hey Jeepers,
new to the site, but seeing if i can scavenge up some advice. I've replaced the 2 pairs of turn signals up front and the brake and reverse lights in back with LEDs. Also replaced stock flasher relay with EP26 relay (same 4 pin design as stock). With everything off, the hazards work just fine. with the ignition on and headlights off - turning on the left signal causes the left front to blink and both tail lights to blink. turning on the right signal will cause both front signals and both rear signals to blink. in no scenario can i get the side marker lights on the fender flares to work. I figured the LEDs might be polarized so i tried all the combinations of flipping those around and that didn't change anything. If i turn the parking lights or head lights on, left front signal is steady as it should be and right is out, rear is good. when i add left signal to that, everything is fine except right front is still out. when i turn on the right signal the right front and back will blink as normal. i was able to read about 6.1 volts to both side markers, not sure, but i guess i was expecting to get 12V there. i guess just looking to tips on how to trouble shoot, and maybe the best place to start that process. thanks in advance!
