Removing factory tail light housings with factory halogen bulbs and replacing with led lights. The rugged ridge aren’t plug and play so I had to snip the connector. When snipping, you are left with four wires on the left and three on the right.
There’s no instructions on how to match what wires from the new led bulbs to the factory wiring.
In the end I figured it out.
Green/white matches to green from led.
Yellow/white matches to black from led.
On the left side, green/red matches to red from led.
On the right side, brown/red matches to red from led.
The left fourth wire (brown/red) is capped and unused.
These weren’t working when I first tested but as another user pointed out, the housing has to be fully connected and screwed back to the Jeep so that the ground connection is made. This was my problem.
In the end, all worked out. Just took me forever.
