TJ Fest 2021
LED turn signals & marker lights causing alarm to go off
bigtermites
Alexandria, VA, USA
I recently added tube fenders on my ’05 LJ and that required me to add LED turn signals and a LED marker light to pass VA safety inspection. When I turn on my headlights the no seat belt type alarm goes off. Grounds have been checked. Anyone have a idea on a fix?
Thanks
Chris
Administrator
Staff Member
Florence, AZ
The side markers on the fender use a floating ground. Anytime you replace them with LEDs you will run into issues unless you solve that floating ground issue. Not entirely sure what the solution is (other than replacing them with halogen bulbs), but I believe @cr0sh has a thread where he details what he ended up doing for his.
Daryl
2004 Rubicon
Earth 🌎
You can add some diodes to get them to work close to original. That’s what I did.
