While tightening the arms onto the SwayLoc, the provided tool stripped the threaded end of the inner swaybar (this makes more sense if you're actually installing one).
Taking everything apart, I realized that due to overly tight manufacturing tolerances, a burr had formed on the back side of the arm and caused it to bottom out about 3/16" too soon. Having not realized this at the time of install, I kept tightening it down until it stripped out. Ugh!
Hopefully ORO will send me out a replacement part tomorrow or else I'm going to have to clean up the burr and drill and tap the thread to a larger size.
Anyway, if you're installing one I'd suggest starting it and then back it off again to make sure a burr isn't forming. The trouble is that it's difficult the entire way so you don't know if it's still sliding or bottomed out. If a burr is forming, don't grind away any more than the burr or else you may end up with too little contact between the parts... Maybe ORO will take note and double check their manufacturing tolerances.
