Thank you
@Wildman you bring up a good point, as far as I know, all the 3.0l TDI comes with automatic which means you would have to figure out how to disable that portion of the ECU as well.
The 4BT is WAY too big and heavy for the TJ Wrangler. It's 782lbs and will rattle the fillings out of your mouth as well.
@TJ_Tim the other thing to consider is swapping to another transmission like the Ford 6r80, it's not cheap, but it's what I'm going to be running. Granny low first gear of 4.17:1 and it has two over drives as well, a .86:1 5th gear and .69:1 6th gear, this will vastly improve the fuel economy from your engine, and with the low first gear as well you will be able to easily move your bigger wheels and tires without having to have the 400ft/lbs of torque.
If anything check out the OM606, from what you are talking about that might be the motor for your for your goals.
One last thought for you though, I'm going to swap my Jeep Liberty CRD (Common Rail Diesel) turbo diesel drivetrain into my LJ Rubicon after I finish my current swap. I've done all the upgrades and fixes to the motor already and it's 190hp and 330ft/lbs of torque with a 454rfe automatic transmission as well. The weird thing is my Liberty weighs a little over 1200lbs more than my LJ Rubicon. That 330ft/lbs of torque made that entire Liberty move! It was a blast to drive, but having it in a LJ Rubicon is going to be so much more fun as it weighs so much less.
Thanks
Grant
