Completely overlooked the clutch fluid in my fluid change cycle. Yesterday I saw a small spot of unknown (clear, odorless, slightly slick) fluid on the floor mat on the drivers side. That far over to the left must be clutch...
Clutch feels normal. Brakes are fine.
Haven't gotten up under the dash to check around yet. Any thoughts as to what fix I am facing with this leak??
Checked the clutch master cylinder reservoir. What's the proper way to service this? Do you fill the rubber cup or remove the cup, fill with reservoir with DOT 3 and the replace the empty cup in the reservoir filled with fluid?
I think the rubber cup is supposed to come out with the cap on the reservoir. Then fill and replace the rubber and cup leaving the cup empty.
Now, about that leak...
