I know this has been discussed ad nauseum but I can’t really find my answer via search.
I can do without the “wtf is wrong with you?” replies so just move along if that’s what you’re feeling.
Just purchased a very clean 04’ LJ. 80k, mostly stock suspension from what I can see. It was set up to be pulled behind an RV. Allegedly had some heavy duty shocks installed. Unsure if springs are OE. Compared to my 01’ sport TJ which rides nice and soft, when the 04’ hits a bump or pot hole it’ll knock your fillings out.
So I’m planning on having either 31x10.5/15 or 265/75/16s put on. I ended up buying some
OME 2” front shocks ( extreme terrain J168913),
OME 2” rear shocks (extreme terrain J168916),
OME 2” light load front springs, and
teraflex 1.25” rear spring spacers.
I intend to have an alignment done after I install everything. Im hoping this gives me some better ride quality, a little level and a bit of room for the new tires. I’m 95% on road weekend garage queen.
Question, what should I be doing with my bump stops front and rear and will I need to address anything else like control arms, track bar, etc..?
Thanks guys.
Thanks guys.
