Yes, I installed 2" bump stops on the lower perches, since it was a 2" lift. Next move is to cycle the suspension to fine tune if neededDid you lengthen the bumpstops/jounce bumpers? I'm sure it can very from Jeep to Jeep.
Old thread, but it looks like you went with the R5000x shocks and Pro Comp springs. How did you like the combo? Did you get all the lift you expected?Well I did it. Ordered according to CodaMans list. Pretty close to 900.00 cdn by the time taxes and shipping were factored in
But hey how does that saying go,oh ya "Buy once, Cry once". (I hope )
Since its my 1st lift install I didn't know what to expect. Also since it and my 97 TJ share 50/50 daily driver duties I didn't go big.Old thread, but it looks like you went with the R5000x shocks and Pro Comp springs. How did you like the combo? Did you get all the lift you expected?
Awesome! Nice looking rig! That's on 31s, right?Since its my 1st lift install I didn't know what to expect. Also since it and my 97 TJ share 50/50 daily driver duties I didn't go big.
Here's a pic of the finished 05 Sport with 2" ProComp lift springs.
I also installed 1/2" coil spring spacers on the front springs only. (Great idea ty @JMT).
Finished product is level. TJ is otherwise stock. The ride is firm, not uncomfortable, with new Rancho 5000x shocks.
Yes 31s. Knew I forgot something.Awesome! Nice looking rig! That's on 31s, right?
Thanks for the explanation and for posting the pics. After some upgrades that added some weight, I'm thinking of a moderate lift to get some clearance back plus some. The Pro Comp / R5000x combo is pretty high on my list.
Nice to see that things came out level with just a small spacer up front. I have a fairly heavy winch up front and a hard top, so I'd expect to sit just a little lower with the same setup. And I'd have to see how things sit to decide if it needs a leveling spacer.
Looked at OME, and that's a possibility. But this setup is a lot cheaper and apparently just as good.You might also check OME lift I believe it's a bit over 2" I'm sure u know all that.
