Limited Slip?
Apr 20, 2016
32
I have a 2000 Jeep Wrangler. The pinion bearing in my rear differential is shot. I am getting ready to order a remanufactured differential. How can you tell if the differential has limited slip? If I get limited slip, does it matter if the front differential has it or not?
Thanks for your help.
Rob5589
Certified video trained differential rebuilder
6,165
W Sacramento, Kalifornia
Jack up one wheel, t/c in neutral, and spin a wheel. It will spin freely if an open diff, and have heavy resistance if LS.
How much for the reman? Have you checked the price of having yours rebuilt?
glwood
TJ Expert
5,655
Albuquerque, NM
Does not matter if the front does not have one if there is one in the rear. Are you wanting to know if your current Wrangler has a LS or if the remanufactured differential does?
Craig Dickinson
Apr 20, 2016
32
Powertrain Products has the limited slip version for $1517.00 + $200.00 to have it shipped to my house. I was hoping to determine if the one that is currently installed has the limited slip. Since it doesn't matter, I think I would prefer limited slip and will probably go that route. There's not anyone around here that I would trust to rebuild my differential. I would do it my self, but don't feel comfortable installing the bearings since I understand that they have to be pre-loaded.
I do have one other question. When I bought this jeep, the seal in the differential was leaking. I installed a 4" lift kit on this jeep. The manufacturer of the lift kit said that an SYE was not necessary since I have a manual transmission. Any chance that they were full of crap and I really need to install an SYE to prevent future failure?
Craig Dickinson
Apr 20, 2016
32
I kind of suspected that. I may go ahead and get the SYE and drive shaft and install them at the same time.
Thanks everyone for the input.
Jeep On.
Reactions: Chris and StG58
StG58
Backwoods Amateur
5,995
Orygun, the wet side...
Oh, have a buddy handy to help you unload that differential. They are heavy and awkward to handle by yourself. The Trucker will just look at you when he / she shows up, most likely. Unless the shipping contract specifically states that they are going to unload at the destination. Then expect it to be laying in your driveway.
Rob5589
6,165
Wow, 1900 for a 35 and Traclok is nuts. I would look into a 44 or 8.8 at that price point. The Traclok is weak and wears clutches quickly. I would put the extra money toward a Truetrac instead if you go with the 35.
Reactions: StG58
Craig Dickinson
Apr 20, 2016
32
Thanks for the input. They are supposed to have a lift gate on the truck to unload it with.
Craig Dickinson
Apr 20, 2016
32
I considered that, but a remanufactured 44 is like double and I really don't abuse the jeep. We take it out on the weekends for some pretty tame trail rides, but no serious crawlin or muddin.
Jerry Bransford
TJ Guru
9,972
Escondido California
Something is jacked up... a pinion bearing would cost $200 at most to have replaced. Why is the entire axle being replaced? And a differential is not the same as the axle. The differential sits inside the axle's center pumpkin area. And a new differential/carrier/case would not be required if only a pinion bearing is being replaced.
Even if a new limited slip differential was being installed it would not require a new axle, which means the delivery truck would not require a lift gate. A new LSD differential would fit into a small box that could be shipped by USPS or UPS and delivered by hand.
I am confused at what just happened.
Reactions: StG58 and Chris
Jerry Bransford
TJ Guru
9,972
Differential is the doodad inside the pumpkin. :)
I was actually referring to the entire rear end.
:confused: Why are you replacing the entire rear end when only the pinion bearing is bad? That bearing and a new Truetrac could be replaced with all the other bearings for half that cost. I would definitely not replace the entire axle, there's no need... you'd be wasting big $$$.
