Hello,
I have a 2005 LJ with a 2.5" OME lift, JKS adjustable track bars front and rear, and 32" tires. Since I got it, it has had a click when you let off the gas. The previous owner said it was the e-brake, and it just needed to be replaced. I know the rear driver side e-brake is frozen open, and the cable is not hooked up to the driver side, only the passenger side. I have them on order to replace them however I think this noise is coming from something other than that. I have replaced the Upper and Lower ball joints, drag link, and tie rod ends because they needed to be done, and I was hoping they were the culprit. The upper and lower control arms were replaced by the previous owner, and as far as I can tell, they look new, and in good condition. It only makes this noise when letting off the throttle after accelerating, or sometimes when shifting from 1st into 2nd. To me it seems like something is shifting to create that sharp click noise, but everything seems tight underneath and to torque spec.
The only other thing I noticed is the front axle is about 1/2" of center to the drivers side, I plan to adjust that this week and recenter it. Is it possible that it adding stress to the control arms and causing the click? I am open to any suggestions, the clicking is driving me insane.
Video link:
Thank you for any input.
Video link:
